Irregular Battery Behavior With Ics
Posted 03 April 2012 - 01:13 PM
Posted 03 April 2012 - 01:28 PM
Posted 03 April 2012 - 01:55 PM
Posted 03 April 2012 - 02:03 PM
-Motocast isn't connecting for me
-NFL mobile closes everytime I try to load a video
-If you write an email and save it as a draft it closes everytime you try to reopen it
Posted 03 April 2012 - 02:04 PM
Posted 03 April 2012 - 03:40 PM
Posted 03 April 2012 - 04:12 PM
Posted 03 April 2012 - 07:35 PM
Could it be the leak itself, or some combination of Klingons left from previous roms? Do any that are having problems have anything besides the leak in common? Sent from my DROID RAZR using Tapatalk
I have completely wiped data/cache twice for other reasons and I still get this erratic battery behavior so I would assume it is a software bug.
#9 Guest_BDH_*
Posted 03 April 2012 - 08:04 PM
Well if it was a software bug, wouldn't everyone have it?
Sent from my Rooted Stock ICS Droid RAZR using tapatalk.
Posted 04 April 2012 - 12:44 AM
Not necessarily. It could be caused by some uncommon condition. For example, if some logic that runs at first boot said 'if battery >50% do X, if less than 50% do Y' and having no 50% exact condition. It would be rare for it to occur because only a very narrow window at just the right time would cause it.
Posted 04 April 2012 - 06:00 AM
Posted 04 April 2012 - 01:51 PM
Posted 04 April 2012 - 05:30 PM
This happens with gmail or the regular email app?I know this may be a bit off-topic but since we're mentioning issues I have encountered some other problems as well that I don't think have been mentioned yet:
Posted 04 April 2012 - 07:02 PM
Posted 05 April 2012 - 08:38 AM
I think i was one of the first ones to mention this in chatroom on my first day using the leak but instead of battery dropping. I recorded getting 80% at one time...left it on my nightstand not charging and took a shower I came back a few minutes later and I was at 100. I praised icecream for that lol but that happened once. After a fresh reboot I'm not seeing that anymore since. But I doubt it if everyone's going thru same thing
