Has anyone had trouble with GPS not working on the aokp_spyder_unofficial_2013-04-21.zip
ROM?
Posted 30 April 2013 - 01:45 AM
ROM?
Posted 30 April 2013 - 09:46 AM
I think those are untested nightlies. I'll upload it for you if you want it.
~ BLUE AOKP RAZR MAXX~
That'd be really awesome man, thanks!
Here you go.
Posted 01 May 2013 - 01:45 PM
Here you go.
For some reason, I can't get mms to work, even with go SMS. Any idea?
Posted 02 May 2013 - 03:14 AM
Yeah I tried it and I couldn't use it cause I couldn't keep my phone booted. Every time I locked the phone it would not come back on when trying to turn the screen on. AOKP MR1 build 6 works a lot better.
~JELLY BEAN FLASHING DROID RAZR MAXX~
How's your battery life been? I've been using hotplug underclocked to 800mhz and cpu sleeper and my battery life is still not very good.
Posted 05 May 2013 - 06:20 PM
I get the same thing. ??
Posted 07 May 2013 - 08:24 PM
Have you tried to skip the email and just signing in to your gmail account?
Posted 26 May 2013 - 07:15 PM
Dear Peeps
I flashed android 4.1.2 using droid razr utility 1.9 jellybean xt912.
option1
I then rooted using the droid utility then installed cw3(clockwork recovery)
option 3
Copied AOKP to internal SD
Rebooted recovery via rom toolbox
Load Rom Slot-3
Create 1gb Rom slot
Install aokp miltestone 1 zip.
Install Gapps
Reboot.
YAY! its slick, fast and responsive and damned if there is no flaw I can find. Havent tested the webtop but who really uses that.
If wi-fi doesnt load reboot and Voila!
Posted 27 May 2013 - 11:32 AM
can you install in the stock slot?
Posted 27 May 2013 - 03:21 PM
No, slot 2 only.
