[ROM] Aviator HD ROM - v1.0.4 [06/20/13]
Aviator Aviator HD ROM ZKK007
183 replies to this topic
#1 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 20 April 2013 - 02:58 PM
POPULAR
(Current Version 1.0.4)
Hi all,
Fly higher with Aviator! This is a DroidRZR.com exclusive. Please do not post this anywhere else without prior permission.
I DO NOT have a Razr HD. Therefore there may still be an issue or two floating around.
FOR RECENT APPS, HOLD THE "HOME" SOFT KEY
Based on 9.16.6 Build.
I am not responsible for anything that may happen to your device. (... nothing should happen)
Click to
  • Deodexed.
  • Debloated.
  • Zipaligned.
  • Init.d tweaks - Performance and Battery based.
  • ADBD.
  • WiFi hack baked in (Use stock hotspot)
  • 1% battery.
  • Reboot in power menu.
  • Recovery in power menu.
  • AOSP Lockscreen.
  • AOSP 4.2 Keyboard.
  • AOSP Browser.
  • AOSP Set up.
  • ES File Explorer (Can be uninstalled, not a system app).
  • Titanium Backup (Can be uninstalled, not a system app).
  • No Frills CPU Control (Baked into settings. I.E. go into settings).
  • CPU Sleeper (Baked into settings. I.E. go into settings).
  • OTA Updater (Baked into settings. I.E. go into settings).
  • Superuser.
  • GPS tweaks.
  • Build.prop tweaks.
  • Ad free baked in (/system/etc/hosts)
  • Custom theme – Wallpaper, boot animation, 3G/4G icons, and semi-transparency.
  • Hashcode, Dhacker, drjbliss - For all their work.
  • mhous33 - 98.72.16 Deodexed base.
  • mattlgroff – Init.d and ADBD installation.
  • trikotret - Screenshots and main tester.
  • droidrzr.com - Top notch site.
  • Please PM me if I have left you out.
  • Transfer to SD card.
  • Reboot into Recovery.
  • Wipe
  • Mount /system
  • Flash boot.img if coming from a different kernel.
  • Flash “AviatorHD v1.0.4”.
  • Reboot after installation.
  • Setup phone.
  • Go into Settings>CPU Sleeper. Check "Enable auto-start on reboot", then "Start Service" (Press twice).
  • Let phone settle for 5-10 minutes then reboot for best results.
  • Charge to 100% for battery calibration or use battery calibration app from Play Store.
  • Enjoy!
  • AviatorHD v1.0.4:
  • Mirror:
    MD5 Sum: a247fe4c82adc2bc76b6eaca193961f3
    (Remember, long press "Home" soft key to access recent apps if using Apex Launcher)
  • 4.1.2 kernel boot.img:
  • Stock Launcher with Circle Widget:
    (Flash on top of ROM)
OTA Updater:
This ROM has OTA Updater installed. When an update is available, you will get a notification. You will then download the update using the app. Once downloaded, you will have to manually reboot into safe strap. The download location is sdcard/OTA-updater/Download/[filename].zip
To Come: ... Eventually :p
Skip Track Mod.
Fix any bugs that might arise.
Perhaps overclocking and modules.
Utility with different options.
AOSP Stuff.
Themes.
Known Bugs:
None so far.
Want to show your Aviator Support with a custom Aviator signature image?
Instructions:
Edit your profile and go to signature.
Copy and paste this text and center it:
Save and enjoy! :)
Kanging Policy:
Please feel free to use anything here for your personal, or public use. If you do use something from this thread, all I ask to to be given credit where it is due. You do not need to ask for written permission unless it is otherwise stated as part of a forum's kanging policy.
Don't forget to"Like" -->
Or if you want to see me get an HD, feel free to Donate (see signature) :)
  • Mr_Alexander, quadjacks, jroc and 23 others like this
Donate? Click on signature :)
#2 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 20 April 2013 - 03:02 PM
Aviator ROM:
Click to
  • JJT211 and zooyork0721 like this
#3 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Aviator Custom Widgets:
(Carried over from XT912)
Instructions:
These were made in UCCW. Please download UCCW from the play store in order to use these files:
  • Download:
  • Unzip to get 2 .uzip files (weather and stat widgets)
  • Move .uzip files to /sdcard/UltimateCustonClockWidget/
  • Create widget by long pressing on screen, select Widgets, then UCCW. Choose 2x2 size.
  • Press menu, "Open uzip"
  • Navigate to /sdcard/UltimateCustonClockWidget/ and select the appropriate .uzip
  • Enjoy!
#4 TjNaps27
TjNaps27
  • 80 posts
  • Twitter:tjnaps27
  • Current Device(s):"Dan" Edition Razr Maxx HD
Posted 20 April 2013 - 03:20 PM
Thanks! Downloading now!
#5 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 20 April 2013 - 03:22 PM
Woooo hooooo I'm popular and thanked
  • BladeRunner likes this
#6 sfg
sfg
  • 81 posts
  • LocationCalifornia
  • Current Device(s):RAZR HD MAXX, Nexus 10
Posted 20 April 2013 - 03:31 PM
***Solved***** USER ERROR
Ok so I have downloaded and installed per your instructions.  When the reboots it just goes to a blank screen.  I can hard reset and get back to the bootloader and recovery but it wont boot into system.
#7 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 20 April 2013 - 03:41 PM
Did you flash the boot.img too?
#8 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 20 April 2013 - 03:45 PM
IF you are on the 4.1.2 just mount system and flash away after wipes. Thats what I have been doing
#9 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
  • LocationNew York, NY
Posted 20 April 2013 - 03:46 PM
lmao how did that guy get first before all the reserves  but woo ;)
  • trikotret and sfg like this
#10 sfg
sfg
  • 81 posts
Posted 20 April 2013 - 03:48 PM
Came from a AOKP build which was 4.2.  I just tried installing RAGE after this and got the same results. I will try and flash the boot.img.
Update... That worked.
#11 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 20 April 2013 - 03:57 PM
Yeah, just for future reference, if you change kernels you will need to flash the boot.img :) I'll update the installation instructions too.
  • sfg likes this
#12 sfg
sfg
  • 81 posts
Posted 20 April 2013 - 04:00 PM
I should've known.  In my mind I assumed the kernels were backwards compatible.  Just enabled and started auto-start on reboot.
#13 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 20 April 2013 - 04:07 PM
Well I didn't Flash Boot.img...Followed the instructions...Create the Slot...Wipes...Install the ROM...Boot that sucker...
CPU Sleeper....Enable...Run Twice on the first Install...Relax for 5 minutes...Reboot again...
"Amen Brother Ben"
Its Bubba
#14 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 20 April 2013 - 04:08 PM
"Amen Brother Ben"
Its Bubba
You have an HD?
#15 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 20 April 2013 - 04:10 PM
Maybe I did When I Enabled...Is that what you mean by boot.img?
Its Running like a Jag....Awesome!!!!!!!
Its Bubba
#16 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 20 April 2013 - 04:11 PM
You have an HD?
Nope,
Currently on my Razr Maxx...Flashing like a Bad Habit...
Its Bubba
#17 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 20 April 2013 - 04:14 PM
Nope,
Its Bubba
This is Aviator HD for the XT926 :D ... I know the OP's are almost identical :p
  • The Persuader likes this
#18 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 20 April 2013 - 04:21 PM
No BS...
Its working on my Razr Maxx...I noticed it said .16 on the Updated version so I said what the Hell I will give it a try...Bingo...
Awesome...
#19 sfg
sfg
  • 81 posts
Posted 20 April 2013 - 04:35 PM
Is there a easy way to disable transparency on the nav bar?
#20 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 20 April 2013 - 04:41 PM
No BS...
Awesome...
Bubba, I think you are running this one:
If you really did get this XT926 version to work then I want to know your miraculous secret! :p
Also tagged with one or more of these keywords: Aviator, Aviator HD, ROM, ZKK007
