Overclock Ics Leak?
Posted 05 April 2012 - 12:45 AM
Posted 05 April 2012 - 03:23 PM
Is there any way to overclock the new ics leak?
Not sure. Have you tried using Matt's Utility yet? (1.51)
Posted 05 April 2012 - 08:06 PM
Don't know what that is.but I'm going to find the zip for adding init.d support and hope that works.
Posted 06 April 2012 - 11:14 PM
Posted 13 April 2012 - 08:15 PM
#6 Guest_BDH_*
Posted 14 April 2012 - 12:59 AM
Posted 14 April 2012 - 02:26 AM
There is no known way to overclock the ICS leak yet.
coryjohn said he had it working...using the normal GB method.
Posted 14 April 2012 - 06:29 AM
Sent from my Droid RAZR (Stock Rooted 4.0.3 ICS) using Tapatalk 2 beta 5
Posted 14 April 2012 - 06:48 AM
I'm not exactly trying to OC but I am trying to set hot plug governor and 600Mhz min freq using ROM toolbox but it won't set permanently, even with Set On Boot checked. Anyone know whats up? Would SetCPU or another program actually work?
RTB worked for me to set hotplug at boot when nothing else would. I didn't try any freq. settings though.
Posted 14 April 2012 - 07:17 AM
Does rom toolbox have su permissions?
Posted 14 April 2012 - 07:31 AM
#12 Guest_BDH_*
Posted 14 April 2012 - 10:13 AM
It won't work simply because the overclock module that you have to flash in order for this to work is built from Gingerbread, not ICS.
Posted 14 April 2012 - 10:34 AM
Yes.
Posted 14 April 2012 - 11:43 AM
Sent from my rooted DROID RAZR using Tapatalk 2
Posted 20 April 2012 - 08:02 PM
I used and set the max to (1200Mhz and the min to 600Mhz and set the gov to Hotplug) and checked apply at boot works 100%. After you set that, download and set your profiles to (Screen Off 600Mhz max 300Mhz min Hotplug 100%) , (In Call max 800Mhz min 300Mhz Hotplug 99%) , And (Screen On max 1200Mhz min 600Mhz Hotplug 98%) and you should be good to go.
