I have the jelly bean update and was able to keep root via voodoo. when I use the rootchecker app, it confirms root is still in place. It looks like SuperUser is not working any more, there is no log activity and when I try update binary, the installed version is 3.0.3.2 and the new version is 3.1.1, when I try to update, I get a message that root access has failed. I do not have SuperUser elite version. I'll gladly pay the $3 if I need to.
I checked SuperUser because when I downloaded SQLite editor so that I can change the entitlement for wifi, I was surprised that SuperUser didn't ask for permission to allow the app. When I run SQL it scans all my apps, but when I go to the motorola settings, it says I have no databases, even when I try to browse manually.
Any idea if there is a problem with SuperUser?
I thought using SQL would be the best option for wifi tethering, but maybe the paid version of FoxFi is easier? I did try the free version, but the data limit for the day is reached pretty quickly.
I don't mind purchasing a few apps to get the tethering set up, but would like to make sure I spend the money to get this to work properly.
Thank you.
