So now that we have the bootloader unlocked and TWRP capabilities, how can we add bootloader and recovery to the power menu without installing a custom rom? I know there are many widgets that can do this and I have one by p3droid, but this shouldn't need a widget/separate app. I'd just like to have it in the power menu. Any suggestions or am I just being picky?
Recovery in Power Menu?
Posted 21 April 2013 - 08:29 PM
Droid RAZR Maxx HD Unlocked/Rooted (JB Stock 4.1.2)
Posted 21 April 2013 - 08:58 PM
I know MHouse posted some mods for the power menu and battery icons in his DST ROM threads, but these mods require a deodexed ROM. Even modding the battery icons and signal icons requires being deodexed (as far as I know).
Here's his thread:
#3 Guest_BDH_*
Posted 21 April 2013 - 09:01 PM
Rage HD has it
- usmcamgrimm and shane1 like this
Posted 21 April 2013 - 09:07 PM
Rage HD has it
Shameless plug. haha
#5 Guest_BDH_*
Posted 21 April 2013 - 09:11 PM
Couldn't help it lol
Posted 21 April 2013 - 10:17 PM
I'd really like to keep my stock rom, just with a few tweaks. I'm past my crack flashing days.(droid x)
#7 Guest_BDH_*
Posted 21 April 2013 - 10:22 PM
That's what Rage HD is. A tweaked fully stock build.
- RikRong and shane1 like this
Posted 21 April 2013 - 11:49 PM
There are a few deodexed stock ROMs running around, but ones like Rage would be better because it would be slightly tweaked for better battery and performance. It's stock themed too. Just flash and you'll be done. If want bone stock, use the DST ROM. You will need to flash again if you want the power options, though.
Posted 22 April 2013 - 05:05 AM
Download it flash it and done. Works perfect on stock
