Has anyone else experienced fluctuating data connectivity on the new JB update? For me, it's not constant but happens often enough to be quite annoying. Sometimes I'll lose my data connection and be forced to either toggle data or Airplane mode to get it back, and when it does come it's 3G instead of 4G. For some reason, it seams to happen mostly at night. Other than that, though, the ROM's awesome.
Signal quality on Jelly Bean update
will4958
, Apr 22 2013 10:16 AM
3 replies to this topic
Posted 22 April 2013 - 10:16 AM
Posted 22 April 2013 - 10:36 AM
I have seen the 3G symbol much more than before since going to 4.1.2. I don't know if it's the update or local conditions though.
Posted 22 April 2013 - 10:43 AM
I'm backing up my apps now and am going to try running the new JB alpha 3 ROM posted by the Blurry Maxx guys and see how that goes.
Posted 24 April 2013 - 01:01 AM
Not seeing that on mine, still the same signal strengths in various fringe and strong 4G areas -- Also, I have been comparing the JB bionic to an OG Razr on 4.1.2 and Gnex on 4.2.2 and the Bionic consistently locks into 4G earlier & more consistently than either of the others
