Overclocking JB
Posted 24 April 2013 - 08:35 AM
Posted 25 April 2013 - 06:32 AM
- maksim likes this
Posted 25 April 2013 - 08:23 AM
In the next version of my kernel I'll have it OCable to 1.4Ghz
just for CM?
Posted 25 April 2013 - 08:36 AM
just for CM?
Yep, only CM. Expect OC in a few days along with Intellidemand, I'm working on them next.
- eanes_87 likes this
Posted 25 April 2013 - 09:45 AM
So...you can edit any voltage values?
Mabye you can create OC kernel with 1.5Ghz?
Posted 25 April 2013 - 10:00 AM
Yes you can edit voltages. What phone can be stable at 1.5Ghz?
Posted 25 April 2013 - 10:16 AM
i think if you can up voltage, then you can make it stable.
maybe you can edit GPU speed to? 512 Mhz or 384Mhz for GPU will be good.
Work only one core in you kernel
Posted 25 April 2013 - 01:50 PM
If you continuously blast your phone with some co2 or other incredibly cold stuff, you could probably sustain that kind of Voltage
Processor is still an OMAP 4430 regardless of the kernel its running
Would be awesome if you (bytecode) could add a thermal throttling table. But as there is no way i've found to monitor cpu temp, I'm not going to get my hopes up.
Posted 25 April 2013 - 02:42 PM
Dtrail already does this and I plan to get around to cherry-picking the commit.
There is a way to do that, and I could incorporate it pretty easily as dtrail has already made it. I'm honestly not gonna spend too much time trying to perfect OCing on my kernel cuz I will always run at stock frequency.
Posted 25 April 2013 - 02:46 PM
Am I the only person who is in love with the idea of thermal throttling?
Posted 25 April 2013 - 02:51 PM
Ehhh I'll pick the commit and max out OC at 1.4. Might pick Live_OC code.
