So today i have to switch to a backup of the stock rom from the cm 10 4.2.1 rom and i was at like 60 % when i did the restore but once i restarted i was back at 100 % any idead why this may have happened and will it affect the way that my battery will work now ? any insight would be great!
Battery Issues
Posted 24 April 2013 - 06:08 PM
Posted 24 April 2013 - 06:17 PM
typically when you switch ROM's, restore backups, etc it will affect the display of the battery..... usually until it is charged completely and the battery gets recalibrated..... usually it is nothing to worry about..... in your specific case, I would say that when you made the backup, your battery was fully charged.... so when you restored the backup it changed the display to what it was when it was backed up.......typically the most accurate display of your battery level is to power the phone off and then plug into a wall charger
Posted 24 April 2013 - 06:36 PM
i have the same problem lol my battery will go down to 1% and sit there for 6 hours, but it has died and recharged many times, any ideas of what i should do?
Posted 27 April 2013 - 05:33 AM
You can use battery calibration in the market. Or manually calibrate, let the phone discharge to 15% or less then power off and let it charge to 100% then unplug and power on. You can also let it discharge all the way but don't do that too often as some people say it's bad and may cause the battery to drain past the point where it can be charged again.
Also it's always best to charge any battery with the device off. This includes phones, laptops, cameras, etc..
