OTA Fail Please Help
Best Answer matjmonk , 26 April 2013 - 08:40 AM
I think at this point you would be best off doing an FXZ using the HoB utility to reset the phone back to stock ICS. Here's the link to the main forum: http://www.droidrzr....ouse-of-bionic/
Here are the steps I would suggest:
1. Read all the information on how to use the HoB utility + the FAQ's
2. FXZ (keeping data) with the HoB utility.
3. root using HoB
4. protect root using HoB
5. reboot the phone and use the Voodoo utility (installed when you rooted with HoB) to protect root
6. test that root is protected by using Voodoo to do a temporary un-root and then restore root with Voodo
7. use Voodoo to temporarily un-root (I've read this is not always necessary, but it should be the safest way to proceed)
8. as long as the test in #6 succeeded, take the OTA
9. restore root with Voodoo after JB is installed, if Voodoo fails use HoB to restore root.
Good luck
Go to the full post
20 replies to this topic
#1 raidermc
raidermc
  • 47 posts
  • LocationWestern New York
Posted 26 April 2013 - 05:53 AM
I have a rooted Bionic running ICS and using VooDoo OTA Rootkeeper to keep root for JB.
I unfroze all apps and even temp unroot but still get update failure.
Any ideas??
It is what it is
#2 matjmonk
matjmonk
    Pack Leader to Bubba
  • 3,662 posts
  • Google+:matjmonk@gmail.com
  • Current Device(s):Nexus 6, Nexus 7 (2013)
Posted 26 April 2013 - 06:05 AM
What error messages did you get? If you're running safestrap you will need to uninstall recovery but you can leave the app in place.
#3 raidermc
raidermc
  • 47 posts
Posted 26 April 2013 - 06:12 AM
No safestrap
I do have ClockworkMod recovery installed.
Does that have to be removed??
Will it remove it self when I uninstall Clockwork?
It didn't give me a specific error message
It is what it is
#4 matjmonk
matjmonk
  • 3,662 posts
Posted 26 April 2013 - 06:27 AM
No safestrap
yes you will have to uninstall clockwork. I'm not sure how that's accomplished since I haven't run it in a long time but I would start by opening up the app and seeing if there is an option there to uninstall.
#5 raidermc
raidermc
  • 47 posts
Posted 26 April 2013 - 06:31 AM
I am uninstalling now and will try again.
Stay tuned and thanxs for your input!!!
It is what it is
#6 raidermc
raidermc
  • 47 posts
Posted 26 April 2013 - 07:13 AM
Uninstalled Clockworkmod still will not take the OTA update.
It displays "The Software update failed"
It is what it is
#7 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 26 April 2013 - 07:21 AM
Looks like you are going to have to fastboot back to stock ICS.
  • tmyinc likes this
#8 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 26 April 2013 - 07:24 AM
You may have to either delete the hijack that bootstrap uses or fxz back to 246. Its been a while but I think the hijack is in the preinstall partition. I also used to delete app data for bootstrap before uninstalling the app. Not sure if that's necessary but I did it anyhow.<br /><br />Sent from my XT907 using Tapatalk 2<br /><br />
#9 raidermc
raidermc
  • 47 posts
I am stock ICS.
Where else can I go with this?
It is what it is
#10 raidermc
raidermc
  • 47 posts
Posted 26 April 2013 - 07:25 AM
I don't have bootstrap installed.
It is what it is
#11 Memnoch73
  • 5,016 posts
Posted 26 April 2013 - 07:29 AM
I am stock ICS.
Sorry I meant out of the box stock. You can try just doing a factory reset. Or you may need some House of Bionic Fxz help.
#12 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
I am stock ICS.
Rsd lite or hob. You can fxz straight to JB or back to ICS but you will have to reroot. That's why I mentioned trying to delete the hijack so you can protect root.
#13 raidermc
raidermc
  • 47 posts
Posted 26 April 2013 - 07:33 AM
How do I go about deleting the hijack?
It is what it is
#14 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 26 April 2013 - 07:34 AM
Then what clockwork recovery do you have. I was thinking the only 2 options were safestrap or bootstrap.
#15 raidermc
raidermc
  • 47 posts
Posted 26 April 2013 - 07:35 AM
I am not sure as I removed the app.
It is what it is
#16 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 26 April 2013 - 07:36 AM
Use a root explorer app and loom for hijack in the preinstall folder. If there is one there delete it.<br /><br />Sent from my XT907 using Tapatalk 2<br /><br />
#17 raidermc
raidermc
  • 47 posts
Posted 26 April 2013 - 07:40 AM
found it!! remove the whole thing or something inside it?
Edit;
There isn't much in there so away it goes.
It is what it is
#18 raidermc
raidermc
  • 47 posts
Posted 26 April 2013 - 08:15 AM
Edit;
Removed hijack Still no luck.
It is what it is
#19 matjmonk
matjmonk
  • 3,662 posts
Posted 26 April 2013 - 08:40 AM   Best Answer
3. root using HoB
Good luck
  • tmyinc likes this
#20 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 26 April 2013 - 09:33 AM
Yep that's the best option at this point.<br /><br />Sent from my XT907 using Tapatalk 2<br /><br />
