Best Answer matjmonk , 26 April 2013 - 08:40 AM
I think at this point you would be best off doing an FXZ using the HoB utility to reset the phone back to stock ICS. Here's the link to the main forum: http://www.droidrzr....ouse-of-bionic/
Here are the steps I would suggest:
1. Read all the information on how to use the HoB utility + the FAQ's
2. FXZ (keeping data) with the HoB utility.
3. root using HoB
4. protect root using HoB
5. reboot the phone and use the Voodoo utility (installed when you rooted with HoB) to protect root
6. test that root is protected by using Voodoo to do a temporary un-root and then restore root with Voodo
7. use Voodoo to temporarily un-root (I've read this is not always necessary, but it should be the safest way to proceed)
8. as long as the test in #6 succeeded, take the OTA
9. restore root with Voodoo after JB is installed, if Voodoo fails use HoB to restore root.
Good luck
Go to the full post
