Weird adb/java need solution, stuck
Best Answer iamhugger , 27 April 2013 - 05:39 PM
SOLVED---Well THANKS EVERYONE for your helpful responses!!! :angry:Because of this I re-installed Windows7 (via recovery disk) started over, problem SOLVED
Sent from my DROID RAZR using Tapatalk 2 Go to the full post
9 replies to this topic
#1 iamhugger
iamhugger
  • 296 posts
  • Locationsouth dakota
  • Current Device(s):droid razr
Posted 26 April 2013 - 09:25 AM
I have latest java installed,SDK, platform-tools, I can adb fastboot, adb devices, everything works accept when I run the Setup.bat/apk multi tool, says "adb not found" It will allow me to set up directorys and even mod .apks, sign, push, pull so on.. But its in the small cmd window, not the normal big one, why is this happening? Googled endlessly/searched XDA, been at it all night, and yes I tried tucs adb guide. What is the deal? Please help! Tyty.
#2 cmh714
Posted 26 April 2013 - 09:33 AM
Not sure what you are trying to do, but did you try and add it to your path statement in your OS? try echo %path% and see if its there (assuming your windows)
#3 iamhugger
iamhugger
  • 296 posts
Posted 26 April 2013 - 09:47 AM
Yes windows 7, I will try it.
#4 iamhugger
iamhugger
  • 296 posts
Posted 26 April 2013 - 09:58 AM
Here is what I have.. C:Program FilesJavajre7bin;C:Program FilesJavajre7lib;C:Program Filesandroid-sdkplatform-tools;C:Program Filesandroid-sdkapktoolother;C:Program FilesJavaplatform-tools I know its a lot but was getting desperate.. Trying every combination.
#5 iamhugger
iamhugger
  • 296 posts
Posted 26 April 2013 - 10:03 AM
None of my \\\ slashes showed up on my post...
#6 iamhugger
iamhugger
  • 296 posts
Posted 26 April 2013 - 10:11 AM
Just trying to get apk multi tool and java working as it was before I wiped my laptop and used restore disks. What got me found was I couldn't get comp to recognize phone via USB when running 4.2.2 ROMs..
#7 iamhugger
iamhugger
  • 296 posts
Posted 26 April 2013 - 11:01 AM
<---------- StUcK
#8 iamhugger
iamhugger
  • 296 posts
Posted 26 April 2013 - 03:46 PM
Well, still no luck, does anyone know what iam talking about? Gonna try uninstalling/reinstalling java..
#9 iamhugger
iamhugger
  • 296 posts
Posted 27 April 2013 - 05:26 AM
And still hangn
#10 iamhugger
iamhugger
  • 296 posts
Posted 27 April 2013 - 05:39 PM   Best Answer
