Testing in TWRP, no wipe of system, no flash of boot.img...
13 replies to this topic
#1 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 28 April 2013 - 10:29 PM
So, I installed Rage on Friday, without a hitch.  I did not wipe system, and I did not flash a stock boot.img before flashing Rage.  I decided to do this based off of my previous experience with my tablet.  This is what I did:
1.  DL Rage and place in external SD
2.  Boot into Recovery and make a backup
3.  mount system, then wipe cache/dalvik
4.  FDR
5.  Reboot recovery
6.  mount system
7.  choose install, and flashed Rage
8.  wiped cache/dalvik
9.  re-boot and setup
With all of these installs, I never wiped system and never flashed a boot.img. The ones that failed might have worked if I had flashed a .img at the same time (doubt it), but I'd be willing to bet it has more to do with the updater script that Tim found, and that was included into the Rage ROM (and looks like Flying Jelly too).  I didn't attempt swapping the script or flashing boot.img with the ones that failed, my phone needed a rest. ;)  I'll try it out later or someone else can add to this thread.
1.  Rage-Good to go, everything works
2.  Flying Jelly-Good to go, everything works, but it prompted me to take the Verizon OTA as soon I connected service.  I'll just freeze updater.apk with TiBU if I decide to set FJ up all the way.  Right now, I just booted back into recovery, backed up FJ so I can have a quick restore if I decide to run it.
3.  Energy-No go.  Failed immediately.  Restore went fine.
4.  Eclipse-No go.  After I attempted flash, I was unable to mount system, but restore went fine
  • Gerland the Oracle, neckchop and shane1 like this
#2 neckchop
neckchop
    pluh!
  • 477 posts
  • Locationatlantic City
Posted 29 April 2013 - 01:39 AM
Awesome post. Thank you. This will help some folks for sure!
#3 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
  • LocationWindy City
Posted 30 April 2013 - 06:18 AM
FYI the boot.img NEVER needs to be flashed on a Blur based ROM. Only time you need to use the stock Boot.img is if you had previously flashed a AOSP, CM, AOKP type ROM to the device as they require there own custom kernel to even be able to run/boot. So if you flash a AOSP style you will FOR SURE have to flash the boot.img of stock software if you go back to a Blur based ROM otherwise it wont boot.
Also on your process of flashing. there is no need to mount system prior to wiping anything. Ppl are just better off making the backup, then wipe what needs to be to follow up with a reboot of recovery, then mount /system and flash away.
Lastly on the flash failures listed. I have not tried Enegry but as far as Eclipse goes yes it comes up failed but it flashed fine & will boot fine. i've been testing for Nitro on my Dev edition since his first build so i know for certain it works. Here is the key tho most of the ROMs that have not been updated since the unlock was put out are designed for use with SS. And until the Dev updates the ROM some ROMs will have issues flashing. I know this seeing as I own the dev edition and for a wk i fought getting ANY rom flashed to it that was setup for SS. Until i figured out the how to get it working i couldn't flash squat. However since figuring it out I've been able to flash any ROM posted even if t was setup for use with SS
  • neckchop, RikRong and shane1 like this
#4 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 30 April 2013 - 07:14 AM
Thanks for the input.  I was 99.99% sure that they didn't fail because of the boot.img, and you confirmed that.  When the flash failed on Eclipse, I didn't think about rebooting to see if it had actually installed.  I just saw that it failed and then restored the backup.  I wasn't sure about mounting system when wiping, I never do it on my tablet, but that's what everyone recommended doing on this phone, so I went with it.  This is the kind of input we need, thanks.
  • neckchop likes this
#5 dreamjaeil
dreamjaeil
  • 107 posts
  • Current Device(s):xt907
Have you tried flashing new elemental X for M? I got error 7 on cwm
#6 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 30 April 2013 - 07:21 AM
I haven't tried it out yet, it just came out today.  It's also still in test phase, so I probably won't touch it until a stable build comes out.  Also, it appears it is not based off of stock, so you'd need to flash a stock boot.img to go back to a stock ROM.
#7 dreamjaeil
dreamjaeil
  • 107 posts
Posted 30 April 2013 - 07:29 AM
Well since nitro doesn't have working razr m, I thought I would help out by giving him feedback and such. Sooner he gets the wrinkles ironed out faster we get stable Rom.
#8 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 30 April 2013 - 07:30 AM
That's true, testers are always needed.
#9 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
Posted 30 April 2013 - 08:06 AM
Anytime that is what we are all here for.
As for the mounting thing, yeah there seems to be some confusion currently, and IMO i think it stems from the big change gong to unlocked and a custom Recovery vs old way for most ppl using SS. i've had a Dev edition since day one as i refuse to buy locked devices so I'm use to it I guess.
#10 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 30 April 2013 - 08:12 AM
I'll tell you what, you have more nuts and more patience than I do.  There has been very little development for the Dev device, and your persistence in getting things working on it is commendable.
#11 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 30 April 2013 - 09:52 AM
Where is this new ROM at? Can't seem to find it lol
#12 dreamjaeil
dreamjaeil
  • 107 posts
Posted 30 April 2013 - 10:08 AM
It's at nitro's new site. Elemental X designs
  • brandon71 likes this
#13 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
Posted 30 April 2013 - 10:38 AM
LOL...... I'm not one to give up when I know it can be done. and yeah at the time there was not squat to use on the Dev edition until i figured out a work around to be able to use SS ROMs on my Dev Edition devices without using SS. At the time I felt it defeated the purpose of owning a dev edition to have ot use SS so i was on a mission to get ROMs flashing right on my Dev Edition M or HD.
  • neckchop and CamoCustom like this
#14 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 30 April 2013 - 08:07 PM
It looks like a pretty nice ROM.  I'll keep an eye on it and might try it out when a stable build is released.
