My device is rooted (Jelly Bean - thanks, Dan!). I purchased SQLite Editor, went into settings, set entitlement value to 0. The first few days, I could select mobile hotspot and wifi tether other devices to my Bionic. Now, when I try to select mobile hotspot, it turns on, send a signal, and then almost immediately turns itself off. I've tried several times, checked that the entitlement value is the same. Hotspot continues to turn itself off. Any thoughts on what else I should be doing? Before I was able to root, I did use FoxFi (the free version for a few days). I uninstalled that app before rooting, I can see FoxFi network name greyed out in the background now. The first few times I was able to use the hack to tether, the network name came up as FoxFi, not a Verizon name - maybe this is an issue - one I'm not sure how to resolve. Thanks.
