Best Answer SamuriHL , 30 April 2013 - 04:46 PM
You have to edit the xml file and remove the oem flash lines. There's two of them.
Go to the full postBest Answer SamuriHL , 30 April 2013 - 04:46 PM
Go to the full postPosted 30 April 2013 - 09:19 AM
I have seen mentioned in a few places that fxz 22 is available. Where can I find it? I tried using 'cdma_targa_9.8.2O-72_VZW-22_cfc.xml.zip' and I get a flash failure.
Posted 30 April 2013 - 09:31 AM
Posted 30 April 2013 - 09:51 AM
That is the one I tried, RSD Lite v5.7 status says: Failed flashing process. 5/24 oem fb_mode_set -> Phone returned FAIL.
Posted 30 April 2013 - 04:46 PM Best Answer
Posted 30 April 2013 - 06:19 PM
Thank you, I did the edit and I will try the flash tomorrow a.m. when I get home from work. Let you know.
Posted 01 May 2013 - 06:45 AM
Decided not to flash this. My problem with my phone booting up in to AP Flash every time stopped happening. But I will keep the edited version for future use. Thanks again.
Posted 05 May 2013 - 07:59 PM
