Posted 09 April 2012 - 01:03 PM
Posted 09 April 2012 - 01:18 PM
Posted 09 April 2012 - 02:02 PM
Posted 09 April 2012 - 02:25 PM
I use adfree and it works well. I barely ever see an ad. I don't use the symlink option. Just check daily and auto update.
Ive tried adfree and most ads still get through. Not sure why its different. I'm trying the rom toolbox route to see if that makes a difference.
Edit: Well Rom toolbox isnt working either. I set it up, rebooted, and still have all ads showing up.I wonder why my phone is being stupid. Really annoying. I have a rooted phone that I should be able to block ads on and it wont work.
Posted 13 April 2012 - 10:19 AM
Posted 22 April 2012 - 06:33 PM
Adaway has blocked all that I have seen. It is awesome. I would recommend using it over adfree.
weird that it's not working for you though..
Posted 23 April 2012 - 08:01 AM
You downloaded and installed the hosts right?
I've never had any issue with ROM Toolbox.
:-D :-D
Posted 07 May 2012 - 01:48 PM
Posted 08 May 2012 - 08:49 AM
Posted 02 June 2012 - 02:12 PM
Posted 02 June 2012 - 03:55 PM
Posted 03 September 2012 - 09:47 PM
Posted 03 September 2012 - 10:21 PM
More options than most, and I never had an ad slip through while I was using it.
But, I stopped because I realized that those ads are what supports the app developers. Imagine if you had to pay for every single app? So I figure since the ad space is already there I may as well help the devs.
:-D :-D
Posted 03 September 2012 - 10:56 PM
Posted 04 September 2012 - 09:21 AM
There are still some ads that get thru. Mainly on apps like gtunes. I haven't found anything to block ads in that or other music downloaders.
-- Living Life From My RAZR's Edge --
Posted 04 September 2012 - 10:31 AM
-JMSexton
Posted 13 September 2012 - 10:36 PM
- The Persuader likes this
Posted 13 September 2012 - 11:04 PM
I used to use the ad blocker that comes with ROM Toolbox (Pro).
Unfortunately, most of those ads do not support developers. I'm an app programmer, I know. Those ads come through cookies, just like spams on your desktop PC.
Posted 19 September 2012 - 07:15 PM
Has anyone successfully used one of these apps to stops ads on their Razr? I was so happy with no ads when I had my HTC Incredible when going to Youtube but now I'm going crazy! I've tried both of them, and their "alternate" locations for changing the host file, but neither of them work. There has to be some way to do it. HELP!!!
I have used Adfree for about six months. And I change roms about once a week. Adfree has always worked for me flawlessly in two taps every time. I even freeze it after each update of the host file. Needless to say I am rooted. Og Razr. I never see an ad in browser...apps...anywhere on my phone.
Sent from my blazing fast Razr running cm9 using Tapatalk 2
Posted 22 September 2012 - 03:52 PM
I used to use adfree but now use adaway. I prefer adaway cause it blocks many ads that adfree failed to. I also found no success with Rom toolbox.
Same here Adfree sucks and adaway works much better
