Best Answer Memnoch73 , 02 May 2013 - 05:05 AM
You could try the Utility to install it. HERE
Go to the full postBest Answer Memnoch73 , 02 May 2013 - 05:05 AM
Go to the full postPosted 01 May 2013 - 10:01 PM
Having a problem trying to flash clockworkmod using fastboot have tried it a few times still hasnt worked it says its successful but its not there when i go into recovery im using a droid razr m on 4.1.2. jb
Posted 01 May 2013 - 10:36 PM
What phone model? What do you mean not there? After you flash, you need to boot into recovery for the script to override stock recovery. The first time you reboot to recovery, you'll get the dead Android on his back. From here, you need to boot into recovery. On my RazrM you hold vol- and tap vol+ to get into recovery.
Posted 02 May 2013 - 04:53 AM
Did you unlock your bootloader. If not CWM will not work.
Posted 02 May 2013 - 05:00 AM
Posted 02 May 2013 - 05:03 AM
Posted 02 May 2013 - 05:05 AM Best Answer
Posted 02 May 2013 - 07:28 AM
Posted 02 May 2013 - 07:31 AM
That helped thanks for your help
Glad to hear it. Moved to Razr M General, marked solved
