Best Answer usmcamgrimm , 03 May 2013 - 08:40 AM
Ok so I followed some of the guides I found, everything worked great when I tweaked my system ui apk. Then I tweaked settings apk and dropped it in my zip. Well after flashing my nav bar and soft keys disappeared ok so I figured it was just my settings apk I modded. So I reloaded my original zip and the same thing happens. I'm curious what happened? Everything worked fine until I dropped the settings apk in my zip.
It's your SystemUI.apk. Nothing to do with your settings apk. Make sure your images are the right size and that it is signed properly then reflash it.
Tapatalking from the pits of hell with my Slaytanic Rage machine! Go to the full post
