[Request] Cdma Razr Ics System Dump
Posted 11 April 2012 - 07:01 AM
If you'd like to do it, it's very simple. You can either use 'adb pull /system' (no quotes) or you can copy and paste all the apks in /system to your sdcard, then zip all of them, and upload them somewhere.
Like I said I would be very appreciative and greatful if anyone could do this or knows of where to get this.
Thanks for your time,
Blur-craving Gnex User
Posted 11 April 2012 - 07:05 AM
Posted 11 April 2012 - 01:58 PM
#5 Guest_BDH_*
Posted 11 April 2012 - 02:02 PM
Posted 11 April 2012 - 03:24 PM
I have one on my PC. Uploading to dropbox now. Will post the link when its done.
Tyyyyyy so much!
Posted 11 April 2012 - 03:26 PM
I can do this after work.
And ty too! Its kinda weird that there isn't one floating around already...
#8 Guest_BDH_*
Posted 11 April 2012 - 08:39 PM
Completely forgot about this lol sorry!! Here's the link to a clean system.
- frankydroid likes this
Posted 12 April 2012 - 07:27 AM
Posted 12 April 2012 - 09:04 AM
#11 Guest_BDH_*
Posted 12 April 2012 - 09:27 AM
how are you guys getting adb to work with ICS leak? I can't get the drivers working. Whats the trick?
Go to System Settings, then Developer Options and make sure USB Debugging is checked.
Posted 12 April 2012 - 07:48 PM
#13 Guest_BDH_*
Posted 12 April 2012 - 08:09 PM
Thank you so very much!!!!
Very welcome!
Posted 13 June 2013 - 09:41 PM
i know this thread is over a year old, but would anyone still have that system dump folder they could share with me?
Posted 14 June 2013 - 04:33 AM
I can take a look when I'm home later.
Posted 14 June 2013 - 09:05 AM
please and thank you!!! i'd really appreciate it.
