I've posted about the same issue in house of bionic, but that thread doesn't seem to be getting much traffic so I'm trying again here. Hope I don't get in trouble for a double post or something.
I acquired a droid bionic that had software issues. The one time I've been able to get it to boot I checked the version and it seemed to be the on the stock .246, but obviously someone had try to make some modifications because I got error notification popups like what people were seeing before the
unlocking proceedure had been fully worked out. When I go into recovvery and try to do a factory reset I get error messages. Actually, even before I can select the reset option I get...
E:Can't mount /cache/recovery/command
E:Can't mount /cache/recovery/caller
E:Can't mount /cache/recovery/log
E:Can't open /cache/recovery/log
and some other can't mount/can't open errors for other files in /cache/recovery. I've tried to fxz .246 with rsdlite 5.6 and 5.7 (I had 5.6 installed before I noticed 5.7 but I've flashed this same update to several other bionics with 5.6), Setup goes normally but when I start the flash rsdlite just stays on step 1 indefinately. I don't get any errors, the flash process just never progresses at all. I just came across this hob method but I'm running into the same thing. I tried rsd method and when rsdlite opened, it stayed on step one. Acting as if it was working, but nothing ever progressing. In fastboot method...
sending 'mbm' <256 KB>... OKAY [ 0.029s]
writing 'mbm'...
and it just stays there doing nothing forever. Any ideas?
Please don't tell me to read the faq or use the search. I've looked for a solution for weeks and I can't even find anyone else listing this particular problem, and I've tried every flashing and unbricking method I could find.
