ROMs won't install from CWM Recovery
2 replies to this topic
#1 tbird89
tbird89
Posted 04 May 2013 - 02:36 PM
When I try to install a ROM, after I've factory reset and cleared the cache, the text in CWM actually says "ROM successfully installed." But when I reboot, my phone is just factory reset on stock ROM. I've tried installing both RageHD and Nexesque, getting the same result both times.
Anyone know why this is? Thanks!
#2 droidian1441
droidian1441
    News Leader
  • News Team Leader
  • 474 posts
  • LocationVirginia
  • Current Device(s):HTC One M8 (primary); Nexus 7 (2013)
Posted 04 May 2013 - 06:29 PM
Well, are you sure its full stock? Cause both Rage HD and Nexesque are stock based.. It could be just the rom installed but not enough was changed? I've run Rage HD and I've done this before.
If that's not the case we can still continue to look into it for you!
--Sam
HTC One M8 // 3.28.605.4 // CleanROM 3.0 w/HarmonKardon audio // Android 4.4.4
n5SOtgv.jpg - "White Noise" out November 4th!
(Recommended)
#3 4638jay
4638jay
  • Current Device(s):motorola razr hd
Posted 15 May 2013 - 03:05 PM
wipe system
