Hey guys!
I am looking for the visual voicemail APK for 4.1.2 for the Razr M. Ive tried a bunch of VVM apk's for JB and none of them seem to work. I can install them but then i get a "your phone comes with visual voicemail features built in" message when trying to run it.
Would someone people able to scrap the APK from the stock and upload it?
Thanks!
I did also trying using an APKshare app where I saved the apk from the stock 4.1.2, used superuser and a file explore to make the system folders r/w and put the vvm apk there. It just fails to install.
Gotta copy to /system and change permissions, then it should work fine. Clicking "install" technically installs it to /data and doesn't make it a system app. Copy to /system/app, change permissions to match the others, then reboot. It should be there
