I was running Eclipse 1.2 on stock slot. I decided to fastboot back to stock 4.1.1. However, now I'm stuck on boot loop and can't figure out how to get back too stock recovery so i can factory reset.
Stuck in Bootloop after Fastboot
Posted 06 May 2013 - 10:50 AM
Posted 06 May 2013 - 11:05 AM
Got it. I plugged it in using the TBH adapter. When I unplugged it, it actually turned off and I was able to get booted into recovery and wipe everything.
- neckchop and shane1 like this
Posted 09 May 2013 - 04:46 AM
FYI if you ever get stuck in a bootloop like that do this. Hold Vol up & down plus you power button all at hte same time. As soon as you see your screen flicker let go of all buttons and then instantly press them all again and the Bootloader menu will pop up. from there you can use Vol down to get to the selection you need/want, then press vol up to make selection.
- hillmom and RikRong like this
Posted 09 May 2013 - 05:18 AM
Thanks. I was using all 3 (but not hitting them again immediately) and getting constant reboots and boot loops. Have I mentioned, I miss the battery pull
