Ad blocking
Posted 07 May 2013 - 11:37 AM
Posted 07 May 2013 - 01:11 PM
- neckchop, in99flames and shane1 like this
Posted 07 May 2013 - 03:08 PM
Trying the program you recommended. thanks!
Posted 07 May 2013 - 03:36 PM
For those of you familiar with the application called ROM Toolbox PRO or ROM Toolbox Lite, the above is the Ad Blocker application that was used in the app, prior to Google's Playstore making some rule changes, which caused the Dev JRummy to remove it from the app. It happens to be my favorite, and doesn't compare to Ad Away.
- shane1 likes this
Posted 07 May 2013 - 06:55 PM
I also use ROM Toolbox Pro. I can't open that link at work for some reason, but I assume it gives directions on how to start AdBlocker?
Posted 07 May 2013 - 07:22 PM
Posted 08 May 2013 - 06:18 AM
I did purchase ROM Toolbox pro. If adaway does not do the trick well enough I'll try that link. Good to see we can still get that section of the application still
If you did purchase ROM Toolbox Pro all you need to do is> open the application> slide the screen to the left> find the "DNS Changer" and long press on it> that will open the Ad Blocker, go ahead and adjust the settings, save it and reboot.
- RikRong likes this
Posted 08 May 2013 - 10:46 AM
I was able to find and install adaway using the F-Droid app at
It's like the hackers version of the Play Store. Just search adaway, DL and install and no more ads!
Posted 07 June 2013 - 09:15 PM
I thought I would add one more just in case it got lost somewhere and somehow.... Anyways it is Ad Free, for those of you that remember using the old SuperUser and getting the mention to try the Ad Free app, well the logo has slightly changed but still has the same setup, also it plays nicely with other Ad Blockers, which 2 is better than 1 right?
