Questions For A Themer
Posted 12 April 2012 - 08:55 AM
Posted 12 April 2012 - 10:03 AM
Posted 12 April 2012 - 10:24 AM
Theme's are much more time consuming with ICS.
Posted 12 April 2012 - 10:34 AM
I know its crazy it will take some getting used toAlso look at framework-res, blur-res, and moto-res.
Posted 12 April 2012 - 10:35 AM
Posted 12 April 2012 - 12:53 PM
Im sure ill run in to more problems along the way. I'm kinda in a bind now with editing app icons and the app will not install unless I move it to system and reboot.guess im late to the party!
Posted 12 April 2012 - 12:56 PM
No im not sure how to do thatdid you sign the app with you were finished?
Posted 12 April 2012 - 01:13 PM
Another thing is I was themeing the Tether Wifi app and a few others to look more like ICS but I think I F@#ked up by editing a .9 png it force closes when I open the app I think im going to give up on this hole theming thing and leave it to you guys
Posted 12 April 2012 - 01:26 PM
Use apkmultitool to sign your apk's. Google it but I think it's
Posted 12 April 2012 - 01:28 PM
You can't just edit the png and drop it back in. Let me know if I can help.
Posted 12 April 2012 - 01:35 PM
Awesome man I'm checking it out now ill let you know if I need help. I appreciate you guy giving me a hand.9patch png's are easy. Just follow one of the guides and use the tool in the sdk/tools folder to start with. Takes 5 minutes to be comfortable.
Posted 12 April 2012 - 05:17 PM
Heres the link
Yup, that's the one I learned off of to make a few themes. Awesome work!
