Smart Actions... Lovin' Em
Posted 12 April 2012 - 08:17 PM
So far I have a few Actions set up:
Overnight silence... used for silencing the phone during sleeping hours
Dock dimming... used to minimize my brightness while in the dock for efficient charging
GPS off... I noticed at work my GPS icon flashes all night since it can't find me in the steel and concrete building so I turn it off
Honorable mention of the Wifi on/off app from Verizon that turns my wifi on when at home and off when I leave...
So I'm tossing this to all you veterans out there... What Smart Actions do you have set up???
PS I know the shiny newness of this app has worn off for some but please refrain from the obligatory "meh I don't use this crap" comments. Thanks
Posted 12 April 2012 - 09:03 PM
Posted 13 April 2012 - 04:39 AM
Like smart actions but they need to update it to include a 4G on/off by location setting.
Also refine some other options to be more specific about location and more wifi and gps specific choices.
Posted 13 April 2012 - 05:39 AM
Posted 13 April 2012 - 05:49 AM
I am wondering about the wifi action. If I turn on wifi and turn off cell data then am I able to still receive texts and voice calls with cell data off??
Yes cell data has nothing to do with voice or sms text.
Cell data is only handling 3g/4g network for internet and MMS texts.
Wifi has the same function for internet but doesnt handle mms messages.
You only really need cell data on when wifi is not present and you need to get on the internet or send a mms pitcure message or have multiple recipients for a text.
If your in a strong 4G area you may prefer 4G over wifi but wifi is better than 3g as far as speeds go.
Posted 13 April 2012 - 05:50 AM
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Posted 13 April 2012 - 01:44 PM
Posted 13 April 2012 - 02:34 PM
I use Smart Actions, mainly because I'm too cheap to pay for Tasker. One feature that's really lacking is the ability to separately control the volume of different functions. Night time is an example. Since I use my phone for work, and my work is 24x7, I get a lot of emails overnight. I don't want email notifications to make any sound. But if work calls me, I want the phone to ring. I haven't figured out a way to do that with Smart Actions.
Have you set the phone to silent for night but added the numbers you would like to VIP caller? That should do the trick.
Posted 13 April 2012 - 02:41 PM
Check out automateit in the market... idk if the free version allows time triggers but the paid version costs much less than tasker... and you can control individual volume levels...
I personally don't use smart actions, but that is only because I have automateit close programs for me.. (when Bluetooth connects, I have it start Pandora, and when it disconnects I have it close Pandora... I have Bluetooth in my truck and its so convenient to listen to something other than "payola" radio and not even have to touch my phone or take it out of my holster for a short drive to the store)
Posted 14 April 2012 - 10:34 AM
Sent from my DROID RAZR using Tapatalk 2 Beta-5
Posted 14 April 2012 - 01:10 PM
He could use the VIP call asserting in smart actions it would allow the phone to ring when a specific number dials
Agreed. I use this all the time and it works great.
Posted 14 April 2012 - 02:52 PM
The problem is, I could get called by literally 30 or 40 different people. And most of them aren't in my contact list. I even get calls from people I've never talked to before.
How about another example? When I get to work I want notifications on at 3/4 volume. But I want to be able to fire up a game before a meeting starts with the sound off.
I guess I really do need to pay the money for Tasker.
Posted 14 April 2012 - 03:22 PM
Check out the free version of automateit. It just might do the trick for you... here's a link to it:
Posted 14 April 2012 - 06:20 PM
Thanks, I just downloaded Llama. Looks pretty good from the few minutes I played with it. I saw that free version of automateit had some restrictions. I don't mind spending the money for the pro version since it's relatively inexpensive. But I'd like to be able to fully test without restrictions. But if Llama doesn't work out I'll revisit it.
