Audio Jack Problem
Posted 08 May 2013 - 06:00 PM
Posted 09 May 2013 - 03:45 AM
no
Posted 09 May 2013 - 12:15 PM
Yes stopped working this morning, I am trying to figure out what updates I had last night I think it is link to one of them as it was working yesterday at the gym.
Droid Razr Maxx on OTA jelly (rooted)
Posted 09 May 2013 - 12:29 PM
Update after doing some research it appears this problem is common if you store your phone in your pocket. Lint or dirt are blocking the connection some say paper clip, canned air-spray or even liquid contact cleaner to clean out while phone is shut off. I am going to try canned air first see if this work then paper clip and last resort contact cleaner I feel this order goes from least amount of risk to greatest. I will re-post my findings when I'm done.
Update squared_____ canned spray appears to have worked. But if this keeps happening I guess I'll be going back to wireless headphones.
Posted 09 May 2013 - 09:42 PM
Sent from my DROID RAZR using Xparent Skyblue Tapatalk 2
Posted 10 May 2013 - 04:26 AM
"canned air-spray"
This may not be a good idea as whatever was causing the problem is now inside your phone.
Posted 10 May 2013 - 05:04 AM
"canned air-spray"
Isn't the jack closed off to the rest of the phone? So the lint has nowhere to go but out.
