Power Boost/unthrottle Hack
Posted 14 April 2012 - 07:48 AM
Sent from my DROID RAZR using Xparent Green Tapatalk 2
Posted 14 April 2012 - 08:29 AM
Posted 14 April 2012 - 10:51 AM
Posted 14 April 2012 - 11:29 AM
Posted 16 April 2012 - 06:45 PM
Which is working well.
Here the link for 2.5
Posted 17 April 2012 - 08:30 PM
Posted 17 April 2012 - 08:47 PM
- koehn925 likes this
Posted 17 April 2012 - 08:55 PM
Does anyone know how to use this? Do I just flash or are there instructions somewhere???
I second this? It's a zip file with directories in it. No META files for flashing or anything.
Sent from my MAXXED out ICS!
Posted 18 April 2012 - 05:59 AM
Here is the link to Rootzwiki OP
v2.5 INSTALL Per the OP
1. Verify that you are running minimum busybox 1.19.3 and have functional wget command
2. Open terminal and type:
su
mount -o remount,rw /system (if running pb 2.2 type sysrw)
busybox wget [url to be added] -O /system/xbin/makedevice.jpg
3. Next type:
#- If this command fails then type:
chmod 777 /system/xbin/makedevice.jpg
#Then repeat makedevice.jpg command
4. Device will reboot and load terminal for you
5. Type:
su
sysrw
pb
* No need to create backup directory before starting this is done by default
* Just toggle what you want to use
6. Reboot after all mods toggled and other goodies utilized
7. Reap the Benefits
- shawnlee6184 likes this
Posted 19 April 2012 - 02:30 PM
su
busybox wget [url to be added] -O /system/xbin/makedevice.jpg3. Next type:
5. Type:
su
sysrw
pb/*
What is the wget command?? and it says that I have to add a url or something? and this is in the DroidX forum not razr.
Posted 20 April 2012 - 05:31 AM
Yeah I know it on the DX forums. But Said in OP for all devices. I haven't tried or looked into it. Just posting information. Just went back to op it is not up and running the developer has stopped working on it
Posted 21 April 2012 - 10:06 PM
Posted 28 April 2012 - 07:15 PM
