updated kernel
12 replies to this topic
#1 jco23
jco23
  • 414 posts
Posted 11 May 2013 - 09:29 AM
I found a zip file for an updated kernel dated 3.22.2013 (xt907-4.1.2radio.zip), but I have been unable to get it to stick. my process has been:
boot into recovery (TWRP)
mount system
wipe cache
wipe dalvik
reboot recovery
mount system
install xt907-4.1.2radio.zip
the installation reads "successful", and upon reboot into the system, it reads "updating android"...
but my kernel version/date remains the same (same baseband too).
rikrong has given me some pointers too, but to no avail. I'm wondering if i am missing a step.
any help, please?
thanks!
ROM: OSE KitKat 4.4.2
#2 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 11 May 2013 - 10:05 AM
I am at a pretty good loss here, too.  One thing, though, don't mount system before wiping.  Just go into recovery and straight into wiping cache/dalvik, then reboot recovery and mount system before flashing.  Also, try this file that Tim posted.  I think it's the same one that I sent you and that you've already tried, but it never hurts to try again. ;)
#3 jco23
jco23
  • 414 posts
Posted 11 May 2013 - 10:12 AM
Thanks. I now noticed that my baseband changed. So thanks for your help rikrong.
And I guess that is more of a radio update rather than a kernel?
  • hillmom and RikRong like this
#4 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 11 May 2013 - 10:15 AM
Woot!  What did you do differently?
#5 jco23
jco23
  • 414 posts
Posted 11 May 2013 - 10:20 AM
I think I was only looking at the kernel and not the baseband. But if that is the only thing that updates, then I guess I'm good.
#6 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 11 May 2013 - 10:25 AM
Yeah, that's the only thing that will update.  You need to flash the boot.img to get the kernel to update.  The new baseband looks good.
#7 jco23
jco23
  • 414 posts
Posted 11 May 2013 - 12:01 PM
do you have a link to the boot.img?
#8 iamhugger
iamhugger
  • 296 posts
  • Locationsouth dakota
  • Current Device(s):droid razr
Posted 11 May 2013 - 01:50 PM
what improvements will this make?
#9 jco23
jco23
  • 414 posts
Posted 11 May 2013 - 07:09 PM
The radio or the kernel? The new kernel supposedly improves WiFi connectivity. Not sure what the new radio improves.
  • iamhugger likes this
#10 jco23
jco23
  • 414 posts
Posted 12 May 2013 - 10:26 AM
updating just the radio was not a good idea.  my phone struggled to maintain a 4G connection and drained the battery very quickly.
#11 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 12 May 2013 - 12:39 PM
Really?  I had no issues with it.  I'm not sure what to tell you.  You can fastboot and completely install 4.1.2, then flash a 4.1.1 boot.img to use Energy.  Actually, a complete fastboot sounds like a good idea.  After flashing the radio, I never had issues with 4g connectivity and got improved reception in low reception areas at work (read, 1x areas now getting 3g).  You might want to just start clean.
As for the stock boot.img for 4.1.1, I think there's one linked in the MRage and Flying Jelly threads.
  • neckchop likes this
#12 neckchop
neckchop
    pluh!
  • 477 posts
  • Locationatlantic City
Posted 12 May 2013 - 01:56 PM
Id have to agree with Rik, as fae as my experience goes so far. The new radio is the only part if the update that has been flashed to my phone so far. Battery seemed to have stayed about the same, but signal has improved noticeably. I work in a concrete building on a fringe 3g/4g area, and it my data seems more consistent in more parts of the building now. Also stronger sign up and down Tue coast in solid 4g areas.
#13 jco23
jco23
  • 414 posts
Posted 12 May 2013 - 03:51 PM
well, it was not a good experience for me.  I do live in a relative weak 4G area - but I have not had that kind of battery drainage (down to 37% after just 5 hours) since being on my Samsung Droid Charge.
