I'm going to try and flash Flying Jelly bean tonight (my first time flashing a custom ROM on my Bionic), I'm rooted and installed Safestrap 3.11 last night.
(1) Do I need a particular size or class SD Card? I'll need to buy a new one as my only SD has Win32 images on it that XDA suggests I keep as is for my Nook Color.
(2) Once I flash, can I delete the ROM files from the SD card? I'd kept the CM10 rom zip on the sd card mounted in my nook and that was causing booting problems, I didn't know initially, at least with the Nook, I'm supposed to delete the zip once installation is complete through CWM. Not sure if the same principle applies to the Bionic.
(3) Can I unmount the SD card once I'm all set up? I back up everything on DropBox and/or my external hard drive and don't normally use an SD card.
(4) I assume I should put my Titanium back up file on the ext-sd before flashing?
Thanks.
Wish me luck.
