Razr Car Dock And Media Dock Mod To Fit Razr Maxx
10 replies to this topic
#1 Jimmy8881
Jimmy8881
  • 36 posts
Posted 19 April 2012 - 06:11 AM
heres a cheap idea i had to modify the original razr docks to make them work with the maxx, useful for anyone that do the battery conversion and dont want to buy a new dock.
all is used is: black foam sheet - $0.50 cents
double sided tape - $3.00
electrical tape - $0.75 cents
make sure you remove the insert on both docks.
  1.48MB   42 downloads
what i did here was put double sided tape first, then the foam, then a few layers of electrical tape on top to make sure the phone is level with the connector on the dock. plus the electrical tape is almost the same color as the dock so it doesnt look that bad.
  1.84MB   59 downloads
here all i used was double sided tape and foam, the phone slides in place nice and easy, i might be replacing the double sided tape with some kind of glue as the bends on the tape doesnt seem to want to stick too well.
  1.67MB   51 downloads
  1.6MB   42 downloads
  1009.72KB   28 downloads
  • Thach likes this
#2 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
Posted 19 April 2012 - 11:01 AM
That's some nice work you did there. The foam seems like it will give it a little bit more protection too. Less wear and tear on the sides of the phone since its not plastic on plastic.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
#3 shizumie
shizumie
  • 650 posts
  • Google+:shizumie@gmail.com
  • LocationHortens, Ga
  • Current Device(s):DNA
Posted 19 April 2012 - 02:30 PM
Wonder if theres a way make it fit with oterbox commuter
I am :ph34r: fear my blade!
#4 mrmuggyd
mrmuggyd
  • 25 posts
Posted 20 April 2012 - 12:16 PM
I would be interested in that also. It's a pain to remove the case everytime I want to use my car dock.
#5 MrC1122
MrC1122
  • 8 posts
  • Google+:MrC1122
  • LocationIndiana
Posted 24 July 2012 - 05:19 PM
u can get a $5 soft gel case from ebay and get the same results, u just have to give it a firm push to make sure it connects with contact pins.
I don't know karate...but I know kaRazr!
#6 pbaur
pbaur
  • 6 posts
Posted 24 July 2012 - 05:43 PM
Now I'm somewhat confused. Motorola lists the same multimedia dock for the razr as well as the maxx (don't know about the car dock).
Thus, why is there a modification needed to make the maxx fit? Am I missing something?
We have a razr here in the family, and I was about to get me a maxx, obviously planning on sharing the dockā€¦ ain't that possible then?
#7 sherri
sherri
  • 288 posts
  • Twitter:sherri64
  • LocationMy own personal hell....
Posted 24 July 2012 - 05:50 PM
Dock and car dock are 2 different things. Desk dock fits both Razr and Maxx both in and out of cases. Car docks ate sold separately for each phone. Neither car dock works with case.
Sent from my Droid Razr using Tapatalk 2
Disappointed and hurt. Not surprised.
#8 pbaur
pbaur
  • 6 posts
Posted 24 July 2012 - 05:54 PM
Great, glad it works for both. Thanks a lot for the quick and helpful answer!
#9 MrC1122
MrC1122
  • 8 posts
  • Google+:MrC1122
  • LocationIndiana
Posted 24 July 2012 - 06:32 PM
not totally correct. i purchased a kit from vzw that contained desk and car docks, usb cable with charger adapter, hdmi cable and headset. the car dock does work with a soft gel case after removing the dock insert. kit was $100.
#10 pbaur
pbaur
  • 6 posts
Posted 25 July 2012 - 02:24 AM
Better still :) thank you for the input!
#11 TweakedSystems
TweakedSystems
  • 122 posts
Posted 25 July 2012 - 03:01 AM
I have to say the Razr has the worst car docking station and media station EVER! why could they not of stayed with the Droid X design in the first place? I had no problems with my X :) I've had nothing but problems with these pieces of crap .such a waste of money for such a lousy design . I myself did the exact same thing you posted here. I use velcro instead and used the soft side. works much better.
Good post
