I made the decision to flash back to a stock kernel using the Razr Utility as there are a lot more roms that support safestrap anyways. However When i do I get <Bootloader> Variable not supported and then it skips over flashing anything and it just wipes userdata. Any suggestions?
Flashing Stock Kernel
Posted 18 May 2013 - 02:42 PM
Posted 18 May 2013 - 03:17 PM
Sorry, more info to put here, when i boot up it will get to the end of the animation then just stick there. I can force a reboot and get to TWRP but none of my backups are there and i tried copying them from my pc. But it's been sitting here "copying" for a good 30 minutes, granted it's 3 backups but it shouldn't take this long should it?
Posted 18 May 2013 - 05:37 PM
Sig by
Posted 19 May 2013 - 05:38 AM
I've already done that but im saying i was trying to get them to where TWRP loads them from which is at /data/media/0/twrp/backups.. So i've been attempting to use TWRP's file explorer but it kind of just hangs there.
Posted 19 May 2013 - 09:22 AM
Why not have TWRP pull recovery from the external directly? In recovery at the top there are two buttons. One for internal one for external
- StATic likes this
Sig by
Posted 19 May 2013 - 03:26 PM
I feel a little dumb xD I hadn't noticed that until just now, back up and running pacman Thanks for the help.
- livinginkaos likes this
Posted 19 May 2013 - 05:29 PM
Sig by
