Best Answer brucipher , 20 May 2013 - 06:57 AM
Never mind. I just found my backup folder using search in root explorer and copy and pasted where I needed to.
Go to the full post
Go to the full post
Posted 19 May 2013 - 03:53 PM
Posted 20 May 2013 - 06:57 AM Best Answer
Posted 20 May 2013 - 07:39 AM
Glad you got it. Thanks for posted what you did to fix it
Marked solved. Moved to HD General
