Stereo Bt Headset
Posted 23 April 2012 - 01:47 PM
So far the three that have peaked my interest as possible replacements:
JayBird Freedom 3 :
Plantronics BackBeat Go :
Novero Rockaway :
Posted 23 April 2012 - 02:20 PM
Posted 23 April 2012 - 02:55 PM
I'm leaning towards the Novero Rockaways more though. They look capable of sustaining what I'll be using them mostly for (running, working out, or just rocking to go tunes).
Posted 23 April 2012 - 04:25 PM
Dont know is this is completely different than your looking for...but I have use the same one for the past 3 years. Just replace the head phones when they break/tear
Posted 23 April 2012 - 05:03 PM
Posted 23 April 2012 - 06:28 PM
They are inexpensive, if that is a factor for you.
Posted 23 April 2012 - 09:42 PM
After trying a wide variety of headphone types, I find I like the secure fit and sound of in ear designs. I guess those years of me having to wear very uncomfortable over ear head sets while controlling air craft and messing with satellite relays in the navy, made me despise them.I see your options all are in ear bud style (which I personally hate) I bought a pair of best buy brand headphones (rocketfish) and I've been extremely happy with them:
Posted 24 April 2012 - 05:33 AM
I'll report back after I've tried them out.
BTW, I also have used the street2 for about 3 years and have had no problems with it. As far as the reports of sub-par microphone I use the neck chain when only listening to music, but if I will be talking on it I also clip it up closer to my chin. When driving I clip it on the seat belt and people have no trouble hearing me on their end.
Posted 24 April 2012 - 05:44 AM
I ordered this and should have it today:
I have a pair of these for work and they dont sound the greatest. I work around machinery and normally have ony one bud in and being able to keep the other out of the way via magnet is a godsend. I have a pair of sony bt buds for normal use.
Posted 24 April 2012 - 08:39 AM
Besides, I'm not a fan on the way it rests on the neck (just my personal opinion of course).
As for my issues with the Street 2... when on call and talking, I always had it clipped just below my chin (and when driving on my belt like stated).
Posted 24 April 2012 - 01:40 PM
Form/Ergonomics: I really wanted something that would eliminate the problem of cords getting tangled or caught on stuff. Why have a BT headset if you still have to mess with cords? The LG is perfect. After a couple minutes on my neck I couldn't even tell it was there anymore. The short (adjustable) cords from the unit to my ears are completely out of the way with no risk of snagging on anything. The controls are laid out well with the music buttons on the right and the send/end button and volume rocker on the left. The on/off switch is also on the left, back and down out of the way, but still easy to get to. After a quick glance at the buttons I put it on and could easily control everything by touch. One nice thing is the ability to switch between normal and bass-boost by holding both volume buttons for a second.
Pairing/Operation: I turned the headset on, tapped search for devices on my Razr and after a few seconds it was paired and connected. That couldn't have been easier. Turning it off or getting out of range was no problem; re-connecting was immediate each time. The range is much better than other BT headsets I've used in the past. I left my phone in the conference room and walked to my office, putting me about 40 feet down a narrow hallway and on the other side of a cinderblock wall. The music continued to play without a break. It did cut out when I got on the far side of a large metal file cabinet in my office.
Sound quality: I have to admit that I'm not an audiophile, but I do listen to music a lot, through both speakers and headphones. The sound through the buds on the LG was great for me. I listened to a variety from Aretha Franklin to ZZ Top and it all sounded fantastic to me. The highs and lows came through nice and clear with all the different genres I typically listen to. My musical tastes tend toward classic rock, but I do listen to jazz, blues, alternative, a little bit of country, hip-hop and R&B on a regular basis. The closest I get to metal is Aerosmith and Led Zeppelin. Personal musical tastes might result in different opinions, but I have no complaints. The volume is more than I need; I couldn't turn these up all the way comfortably. Even driving down the road with the windows down I could hear my music just fine. Also, they sounded just as good at low volumes. This is important to me since I have to be able to hear if a coworker needs me.
Call quality: Just like the music, calls sounded crystal clear and plenty loud enough. I didn't tell anyone I was on a bluetooth, and unlike previous devices, no one asked. I had a lengthy conversation with my girlfriend and we both were able to hear each other very well, with no background noise. Calls connected quickly, and switching from music to call and back to music was instant each time.
Construction: After only a few hours I can't really say much about construction quality on these. Looking them over, they seem quite solid. Like cmorty72 above, I had read about instances of the buds coming off, but I am very careful with things like this so I don't anticipate that being a problem. I will post back on here if I start to notice any problems with the construction.
Overall, I couldn't be more pleased with this headset. It's very comfortable and works better than any others I've tried in every way that it's supposed to. That's my opinion of them. Others may disagree but I would definitely recommend these and I would buy them again.
Posted 24 April 2012 - 08:17 PM
Do you plan on trying to work-out with these on? If so, I'd like to know your assessment on the collar staying put.
Thanks.
Posted 25 April 2012 - 03:13 AM
I will be running in them, hopefully starting tomorrow. I'll let you know how that works out.
- cmorty72 likes this
Posted 25 April 2012 - 07:25 AM
Posted 04 May 2012 - 04:31 AM
Posted 04 May 2012 - 09:52 AM
The LG is the ones I currently have. OK sound quality, great duability, sweat proof, and holds a charge 9-10 hours of music use. Very comforatble as well.
If you have a fat head the motorola are un comforatable. If you have a Really fat head, the rocket fish are uncomforatable at first till they shape to your head.
Edit, I hate buds as well, they drove me crazy for the first week. Just adjust the buds, wear each pair for a day and see which ones work best for you, then after about a week of wearing them, it is second nature. I really don't know who has holes big enough to use the big ones though. Those things are big enough to plug up an elephants arse!
Posted 26 May 2012 - 11:40 PM
Posted 27 May 2012 - 02:24 AM
I have a pair and I have to admit the S9 headphones are a PIA at times they are more comfortable than the S10 HD.
I went with these and I like them very much, if the over the ear is not your thing you could try the S10 by motorola. Make sure you buy them from a dealer tha accepts returns because like all headsets, some people love what they have and some don't Ar
