[TOOL] Ics Installer V1.2 - 6.14.84.xt912 Leak
42 replies to this topic
#1 Rouxe41
Rouxe41
  • 10 posts
  • Twitter:@HandlebarGames
  • LocationMidvale, UT
Posted 26 April 2012 - 03:02 PM
This is a copy/paste of my topic on XDA.
UPDATE 6:18 PM 4/27/12: There is a new version of ICS out for our phones and its ready to be installed with ICS Installer v1.2
UPDATE 9:43 AM 4/27/12: Updated patch! There was an error with ADB in the Motofail root section of the utility, my tests weren't catching it because I have ADB on my path. Sorry everyone! :(
UPDATE 12:57 PM 4/25/12: seems there was a problem with the first option, I have fixed it in a patch. Download it and the bottom of this post and replace the ICSInstaller.bat file in the zip with this one. Sorry everyone. :(
UPDATE 4/25/12: New version of my utility is OUT NOW! I have included RSD Lite in the zip file and the fastboot file that is required to make the switch to ICS. I have updated and thoroughly tested my instructions, and if followed EXACTLY as written, you will retain root after your installation. It is almost 100% fool proof. Enjoy the update! It will be posted as soon as it uploads to google!
Updated:
the root exploit to use latest Superuser.apk and su bin
the process to install ICS
style and layout of utility for usability
full instructions to fix your phone if you do something wrong
added the full 6.12.173 fastboot file
added RSDLite installer with instructions for use(just in case)
added instructions to retain root through ICS install (has worked 100%)
- no terminal app needed
Overall I feel it is much easier to follow, and much harder to screw something up. I just gave it to someone that has no idea what they are doing and they were able to gain root, preserve root, install ICS and regain root access. It is pretty much fool proof
UPDATE: Going though the posts i can see some people are having trouble with the instructions. Sorry I wasn't clearer. You need to have never used bootstrap or safestrap. Rule of thumb is if you've done anything besides just getting root, you're gonna have a bad time.
CDMA ONLY
I know that a bunch of you wanna get your hands on the ICS leak, but can't/don't want to go through all the steps to do so. I have a solution.
I have written a small utility to automate the process.
I am trying to get in touch with mattlegroff to add it to his utility, but in the meantime, I will release a standalone version.
INSTRUCTIONS:
1. Make sure your phone is completely stock 6.12.181 (it's ok if it has been rooted)
2. Make sure you have NEVER installed bootstrap, safestrap, or cwm. (If you have used these, skip option 1 and use RSDLite 5.6)
3. Unzip ICSInstallerv1.2.rar to an empty folder
4. Double click the ICSInstaller.bat file
5. Please READ and FOLLOW all instructions! (you will retain root)
6. You now have ICS!
ONLY WORKS IN WINDOWS!
DOWNLOAD THE USB DRIVERS FIRST!
Please like if this helps you out!
GET IT HERE ICS Utility v1.2not ready... uploading.
TORRENT:
JvFGfnXg3Jo
For anyone having trouble...
DETAILED INSTRUCTIONS:
1. Use option 1 or RSD to get to .173
2. Use option 5 to get OTA walkthrough
3. Use option 2 to root
4. Use option 4 to preserve root
5. Use option 7 to upgrade to ICS 6.14.84.xt912
6. Use option 8 to regain root after upgrade
REMEMBER TO READ ALL INSTRUCTIONS AFTER PRESSING ENTER TO CONTINUE!
  • dcolest44 and W0017roid like this
#2 theonlycosmic
theonlycosmic
  • 470 posts
  • LocationCalifornia
Posted 26 April 2012 - 03:29 PM
So I cannot use option 1 if I have ever used bootstrap?
#3 Droid2drummer
Droid2drummer
  • 324 posts
  • Twitter:@imanotemaker
  • Google+:robertclarkga@gmail.com
  • LocationWarner Robins GA
Posted 26 April 2012 - 03:50 PM
Awesome post! Thanks brother.. loving this. Will try if i have time when I get off work. This is the next beat thing to the all in ones..lol Peace!
#4 Rouxe41
Rouxe41
  • 10 posts
Posted 26 April 2012 - 04:00 PM
you can try it to see if it'll work for you. but i tends to work better when you havent used those. I suggest just using RSDLite 5.6
#5 theonlycosmic
theonlycosmic
  • 470 posts
Posted 26 April 2012 - 04:08 PM
You should also link to the original thread...
#6 theonlycosmic
theonlycosmic
  • 470 posts
Posted 26 April 2012 - 04:11 PM
here :)
#7 Rouxe41
Rouxe41
  • 10 posts
Posted 26 April 2012 - 04:15 PM
i posted it at the beginning of OP.
#8 W0017roid
W0017roid
  • 128 posts
  • Twitter:17akota
  • Google+:17akota
  • LocationNorth Carolina/Pennsylvania
Posted 27 April 2012 - 04:16 AM
option 2 keeps coming up as "adb not recognized as a command."
I went into adb and did adb devices and my phone showed up as connected. :/
#9 b_wat
b_wat
  • 79 posts
  • Google+:bwatkins232@gmail.com
  • LocationKnoxville,Tn
Posted 27 April 2012 - 04:31 AM
Did this last night and everything went perfect no problems at all.Thank you for this
#10 W0017roid
W0017roid
  • 128 posts
  • Twitter:17akota
  • Google+:17akota
Posted 27 April 2012 - 05:13 AM
I just used Razr Utility to obtain root. Maybe i got a bad download?
Everything is working fine so far. :)
#11 Rouxe41
Rouxe41
  • 10 posts
Posted 27 April 2012 - 07:29 AM
there was an error in the .bat file. updating patch now
#12 beeryooper
beeryooper
  • 185 posts
  • LocationWisconsin
Posted 27 April 2012 - 09:36 AM
Followed this earlier this week and it worked well. I used RSD to get back to stock .173 and went from there. I did have an issue with RootKeeper not restoring root but the root backup was still there so I just used the Terminal commands and root came back. Thanks Rouxe.
#13 Rouxe41
Rouxe41
  • 10 posts
Posted 27 April 2012 - 01:47 PM
I am updating my scripts for the new leak, should be ready soon.
#14 orcsbane13
orcsbane13
  • 65 posts
Posted 27 April 2012 - 05:56 PM
Might want to pull it for now. Looking like we can't fast boot back.
#15 W0017roid
W0017roid
  • 128 posts
  • Twitter:17akota
  • Google+:17akota
Posted 28 April 2012 - 06:22 PM
I wonder how many people were actually be able to fastboot back.....
Do you think this problem would be fixed once the fastboot files for .181 will be released since you have to be on .181 to update? I think that has something to do with it since you cant upgrade from .744 to .181, you have to go to .173 in between. Might be the same way if you wanna go back.
#16 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 28 April 2012 - 06:30 PM
181 fastboot files are available now.
#17 Guest_BDH_*
Guest_BDH_*
Posted 28 April 2012 - 06:35 PM
Hopefully these help. Thanks for posting these!
#18 Razrmav
Razrmav
Posted 28 April 2012 - 09:50 PM
Im on .84 (the new leak)without root, is there anyway to rsd back to previous versions?
#19 Guest_BDH_*
Guest_BDH_*
Posted 28 April 2012 - 09:56 PM
Nope
#20 ssmaynv
ssmaynv
  • 243 posts
  • LocationLas Vegas
Posted 28 April 2012 - 09:57 PM
Not at the moment.
