droid razr xt 912 in india
droid razr help
6 replies to this topic
#1 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 28 May 2013 - 09:06 PM
i am using razr xt 912(verizon) in india with GSM career,i bought it from US,but i dont have any problem in running gsm sim on it ,,how it happens? but i m using reliance cdma (indian) in a non sim mod in this razr xt 912,so i can easily access gsm and cdma in a single click,but Data not working in cdma mode hows this ..but data works in gsm mode
#2 cmh714
Posted 29 May 2013 - 04:43 PM
Well, not exactly sure....the XT912 from Verizon is a Global Capable phone. Here in the US its ONLY CDMA. When you go to a foreign country, all thats needed is a swap of the SIM and usually changes to the APN information to get it working on the foreign carriers GSM network.
Not exactly sure why you cant get data on the CDMA side, or what to suggest, other than changing the radios  or using the Test Menu....
To get to the test menu, in the phone dialer, dial: *#*#4636#*#*
Good luck
  • aneeshmbabu likes this
#3 neoXank
neoXank
  • 66 posts
  • Current Device(s):Motorla Droid Razr XT912, Motorola Razr HD XT925
Posted 01 June 2013 - 08:46 PM
Data won't work on CDMA outside US.
#4 cmh714
Posted 02 June 2013 - 06:02 AM
Not 100% sure but I dont believe that to be true. I have seen others post that they were able to get data working as well by tweaking the APN info.
#5 nitin
nitin
Posted 30 July 2013 - 11:30 PM
for data to work in cdma , you need a verizon sim
so you will need to programme the number as in the earlier handsets
#6 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 31 July 2013 - 12:39 AM
no I programmed and running data without version sim ...I found fix for that...
#7 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
