Best Answer jl90 , 30 May 2013 - 01:43 PM
OK so I've never had to do this but if I remember right the fix for the SMS problem was this:
Dial this *#*#4636#*#*
Should bring up a menu to select network mode
Select cmda/evdo/lte (or the closest option) lol
Then go and toggle airplane mode on/off.
At this point you should be able to text message
Hope this is correct I am going from memory and I never had to do it personally.
Good luck with this allenb!
If this works like it!
Go to the full post
