Home screen deletion
Posted 29 May 2013 - 06:09 PM
Graphic lag on home button that zooms in and out on a screen switch. If I hit it so it zooms in and out 5 times lag goes away and the transition is smooth. Then later on I'll try and lag is present, I'm thinking its cause of the home screen and home screen HD installed. Any thoughts?
Sent from my RAZR MAXX using Tapatalk 2
Posted 29 May 2013 - 06:12 PM
tapadriving.....hillbilly style
Posted 29 May 2013 - 06:14 PM
Are you on stock..... or custom ROM ..... if in a ROM ... sure by all means give it a shot..... worst case scenario.... it don't work and you reflash the ROM
I'm stock, rooted, oc, no ROMs yet.. But thanks billy for the quick response.
Posted 29 May 2013 - 06:17 PM
Posted 29 May 2013 - 06:20 PM
Been running this way since Xmas leak, installed HD launcher, and circle widget at that time too. But it just gets on me nerves that the transition is lagging when I hit my home button to select another page quicker. Prolly could be a few things partaking to this.
Posted 29 May 2013 - 06:22 PM
Well.... you could still try it...... make a backup first ..... one again, worst case, is fails, .....restore backup or use Matt's utility....
Tru , thanks. I'll have to try..
Been running the home screen launcher for the HD and circle widgets. Can I delete the orginal home screen launcher? Any one do this yet. Just hate the 1sec
As long as you have another launcher installed it is perfectly fine.
- Redalert likes this
Posted 29 May 2013 - 07:42 PM
Indeed....
Posted 30 May 2013 - 01:21 PM
Posted 30 May 2013 - 01:28 PM
Homescreen lives in /system/app
Posted 30 May 2013 - 05:30 PM
Posted 30 May 2013 - 05:34 PM
Ok so it shows the one, which I assume is the stock one. I had maybe thought to see two. The stock and config and HD and config, but no. So if I replace the stock with the HD. On my home switcher should only read the HD and spb shell. Instead of home screen, home screen & spb shell, correct? :
If I understand you correctly than yes.
Posted 30 May 2013 - 05:49 PM
Thanks pal, long day, so typey and talky no worky
- timpohladthomas likes this
