I need to know how to mount my SD card. Its not working but it randomly happen when I installed a ICS ROM over the jb leak. I got system uid error but it now won't mount my SD card wondering if anyone knew y that would happen. My SD card was fine. Thanks
help with sd card.
shawnlee6184
, May 29 2013 07:33 PM
1 reply to this topic
Posted 29 May 2013 - 07:33 PM
Posted 29 May 2013 - 07:37 PM
I'm assuming you were not using the dual boot utility ...... since that's pretty much the only way you can successfully install a ICS ROM on JB........
Assuming also you did this in safe strap?.... you can just delete the ROM slot and flash a JB ROM
tapadriving.....hillbilly style
