[Recovery] Unofficial TWRP 2.5.0.0 for DROID RAZR M XT907
20 replies to this topic
#1 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 30 May 2013 - 08:22 PM
How to Flash:
Download:
DROID RAZR M XT907---
Source:
Thanks to:
TeamWin for TWRP.
Hashcode and Dhacker for STS-Dev Team source.
Djrbliss for unlocking the bootloader & providing root in the first place.
  • neckchop, T3T3droid, tmyinc and 4 others like this
#2 TolyM
TolyM
  • 17 posts
  • LocationSouth Carolina
  • Current Device(s):RAZR M (XT907)
Posted 31 May 2013 - 02:49 AM
Flashed it and its working well so far. however, i haven't tried to do everything on this version yet. (ex restore)
Thanks.
#3 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
  • LocationWindy City
Posted 31 May 2013 - 03:29 AM
Hey Matt real quick I know the older 2.4 version had restore issues on the M yet dhackers 2.5 for HD was fine. I'm guessing all issues are fixed on the M now that you posted version 2.5. Only reason I'm asking is with the 2.4 issue on the M i went back to 2.3.x dhacker originally made so I no trouble.
#4 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 31 May 2013 - 03:43 AM
I created my own tree with some parts of theirs. However according to testing done this does not suffer the issues those builds had.
Sent from my Transformer TF101 using Tapatalk 2
  • Aixelsyd, CamoCustom and TolyM like this
#5 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 31 May 2013 - 05:24 AM
Successfully flashed.  Thanks for the work.
Backup, restore, and flashing all work as advertised.  It did scare me the first time the screen went to sleep.  I do like this better then having the screen on all the time in the older versions.
  • timpohladthomas likes this
#6 Gerland the Oracle
Gerland the Oracle
    Co-Owner and Support Specialist for Team Rage
  • 212 posts
  • Twitter:gerlandh
  • Google+:gerland.hardin@gmail.com
  • LocationJerome, Idaho
Posted 31 May 2013 - 06:22 AM
Works for me also! And i 2nd the screen/sleep thing! scared me at first too!
#7 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
Posted 31 May 2013 - 10:12 AM
Coolio, thx for the feedback/reply bud much appreciated. Guess it is time for some updating on the M & HD then now
#8 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 31 May 2013 - 07:23 PM
works like a charm great job
#9 matthius7
matthius7
  • 26 posts
Posted 31 May 2013 - 09:41 PM
Fastboot flash recovery twrp-1.img is actually the right command if anyone can't get it to work but yea much faster than 2.3
#10 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 31 May 2013 - 09:53 PM
I had no issues with the command that was posted.
#11 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 31 May 2013 - 10:02 PM
Fastboot flash recovery [recovery.img name] is the command <br /><br />You can name the image whatever you like it will still work <br /><br /><br />
  • neckchop and shane1 like this
#12 fluxor2k
fluxor2k
  • 30 posts
  • LocationKnoxville
Posted 01 June 2013 - 01:26 PM
N00b here. What command line are you guys typing this in? Is in the ADB program, or the phone. I unlocked my bootloader and have my M rooted. I also have ADB on my PC. I'm reading a lot about all this but I'm not sure of the step by steps of flashing, mounting etc. I've seen a lot of videos using safestrap. But none using the unlocked bootloader.
So when I DL a ROM or kernal I take the .zip and move to SD. Then flash old system and kernel and cache.... then I mount new stuff? (Nut shell)
#13 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 01 June 2013 - 02:20 PM
Take a look at this it might help you out <br /><br />
<br /><br />Sent from my XT907 using Tapatalk 2<br /><br />
#14 fluxor2k
fluxor2k
  • 30 posts
  • LocationKnoxville
Posted 01 June 2013 - 04:28 PM
Thanks Brandon Its another peice of the puzzle. could you maybe find something that shows me the order of commands? ex. Fastboot... recovery.. flash delvik cache... mount..
im still not clear on the order.
#15 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 01 June 2013 - 05:56 PM
I usually wipe everything twice in this order cache dalvik factory reset then system <br /><br />Sent from my XT907 using Tapatalk 2<br /><br />
#16 fluxor2k
fluxor2k
  • 30 posts
  • LocationKnoxville
Posted 01 June 2013 - 08:02 PM
your using fastboot correct? Ok, so does this wipe kernal as well? if so i could use a link to an awesome kernal to use. as well as a ROM.
#17 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 01 June 2013 - 08:31 PM
Uhm no this is in twrp or ss <br /><br />And yes it wipes your rom and system but when you flash a rom it will flash it's kernel as well <br /><br />Sent from my XT907 using Tapatalk <br />
#18 fluxor2k
fluxor2k
  • 30 posts
  • LocationKnoxville
Posted 02 June 2013 - 06:31 AM
AHHH i got ya now... thank you very much.
#19 brianjamiel747180
brianjamiel747180
  • 100 posts
  • Locationkent
  • Current Device(s):xt907
Posted 05 June 2013 - 01:39 PM
hey matthius i did the command and got
<bootloader> variable not supported
reported max target file size
flash failed
wth am i doing wrong it does the same thing when i try CWM as well please help many thanks
61ZM(0)
#20 Bmplekan
Bmplekan
  • 27 posts
  • Twitter:@plekanb
  • LocationNY
Posted 11 June 2013 - 02:09 PM
Did you figure that error message out? I was having the same issue. I really would like to do it the "proper" way.
Sent from my XT907 using Xparent Cyan Tapatalk 2
