[Recovery] OUDHS Recovery for DROID RAZR HDXT926 & RAZR HD XT925
Posted 30 May 2013 - 08:22 PM
- shane1 and cj360 like this
Posted 30 May 2013 - 11:14 PM
OK I guess I will start not really understanding are we flashing this one in twrp and using both recovery's or are we uninstalling twrp after we install oudhs and starting over with backup's do we understand what I'm trying to say?
Puff the Magic Dragon
Posted 30 May 2013 - 11:20 PM
If you flash this in TWRP I'm pretty sure it will over ride on reboot.
#5 Guest_BDH_*
Posted 30 May 2013 - 11:32 PM
You are overwriting your current recovery (TWRP) and will be flashing and using OUDHS.
Posted 31 May 2013 - 12:55 AM
OK I understand a little more i think lol. So do I need to go into stock and flash this then make a new backup and start over??
#7 Guest_BDH_*
Posted 31 May 2013 - 01:01 AM
Just flash from whatever recovery you currently have installed.
Sent from my Raged Out HD using Tapatalk (VIP)
Posted 31 May 2013 - 01:20 AM
Thank You
Posted 31 May 2013 - 03:06 AM
sig made by
Rinkle McBally
Posted 31 May 2013 - 03:35 AM
Just to clarify an unlocked bootloader is required.
Posted 31 May 2013 - 11:11 AM
Yes
Posted 31 May 2013 - 03:07 PM
Don't be comfortable using fastboot? Feel free to flash it through your current recovery Everyone thank Matt for bringing this cornea burning recovery over to the HD for us.
This zip is for the xt926
I like the flashable ZIP nice work
Posted 01 June 2013 - 04:21 AM
just so we're sure, since this is based on cwm...anything that will flash with cwm will flash with this?
Posted 01 June 2013 - 04:49 AM
All my posted recoveries can flash whats out there
Sent from my SGH-M919 using Tapatalk 2
- shane1 likes this
Posted 01 June 2013 - 05:19 AM
wonderful...thanks!
Posted 11 June 2013 - 04:56 PM
Is this recovery compatible with ROM manager app like TWRP is? The ability to boot into recovery from that the app?
Posted 11 June 2013 - 05:02 PM
I haven't used ROM manager in a long time but I would bet that it would boot into recovery from the app being its cwm based
sig made by
Rinkle McBally
Posted 11 June 2013 - 05:12 PM
just tried it and yes it does got to ouhds from rom manager
sig made by
Rinkle McBally
Posted 12 June 2013 - 01:37 AM
Thank you. I'm going to give this a try.
