Ok so i attempted to flash the new eclipse rom on to my xt907. I created a stock backup using superstrap v3.11. I wiped cache and dalvik then flashed the rom. when i reloaded it went into a boot loop and nothing else. I restarted phone into recovery and tried to load the backup, restarted and still the boot loop. I think i know my mistakes to this point.... A. i didnt use an sd card (please forgive me im a newbie) and im pretty sure i flashed the new rom over my stock one as i did not create a new rom slot. So this morning i went to try and fix it and wiped a bit to much now the eclipse rom and my stock os are gone. when in superstrap if i click reboot and system it gives me a warning that there is " No OS Installed! Are you sure you wish to reboot?" if i do it just goes to a black screen...... so here is my question 1. is there anything i can do! 2. if i get an sd card can i just load a rom onto it and use superstrap to flash it onto my phone?
Thanks for the help guys i know im a newbie and should have read the whole tutorial on flashing before doing it, but thats how we learn right try it one way and if it doesnt work read the directions lol thanks in advance
