Bootloader Help
5 replies to this topic
#1 fluxor2k
fluxor2k
  • 30 posts
  • LocationKnoxville
Posted 01 June 2013 - 05:00 PM
So i unlocked my bootloader  and i cant get back to the bootloader screen on reboot. the warning pic comes up and reboots normal. ive also tried c:\blah blah \fastboot reboot bootloader. Probably a simple thing but i got no idea.
OK i found out what i was doin wrong. i had to do adb reboot bootloader.
#2 neckchop
neckchop
    pluh!
  • 477 posts
  • Locationatlantic City
Posted 01 June 2013 - 06:05 PM
Maybe a silly question, but have you tried powering down and doing the three button hold? Power, both volume buttons? You could also try downloading ROM toolbox, and using the rebooter option on the bottom of the first screen
#3 livinginkaos
Posted 01 June 2013 - 06:26 PM
Also, there is an app called quick boot that gives you reboot options.
  • neckchop likes this
#4 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 02 June 2013 - 05:00 AM
to get to bootloader all you need to do is hold power and vol+ no matter if you have stock or any other bootloader its power and vol+... power and vol- will take you straight to ap fastboot and the 3 together will take you to options screen where you can chose what you want to do.... just thought it will help
#5 fluxor2k
fluxor2k
  • 30 posts
  • LocationKnoxville
Posted 02 June 2013 - 06:35 AM
Thank you. my power and vol+ sends me to android recovery. vol- works. But when i hit all three its sends me to the options for like 4 seconds i dont hav time to choose an option.... is that normal??
#6 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 02 June 2013 - 10:05 PM
Yes, you need to be quick.  Vol- down to the option you want, and then vol+ to go into the option you want.
