Voice Command/Control
software command voice
5 replies to this topic
#1 rduckwor
rduckwor
  • 29 posts
Posted 05 June 2013 - 11:29 AM
Anyone had difficulty with the onboard voice recognition software (NOT Google Voice) on the Bionic since the latest OS update?  I notice it had very poor recognition and then it just simply died.
Now it says "Voice Command has stopped working".
FDR - no joy.
A minor irritation, but it was useful while driving.
Thanks,
RMD
#2 nakedtime
nakedtime
    Sauce Boss
  • 200 posts
  • LocationOhio
  • Current Device(s):iPhod 3gs, Droid 2, Droid Bionic
Posted 05 June 2013 - 05:00 PM
You're on stock and having problems?!?
That seems super weird!
I'm from the internet and so can you!
#3 vdubdan87
vdubdan87
    Divot Repair Specialist
  • 3,221 posts
  • LocationFlorida
  • Current Device(s):Nexus 6 32 GB, Nexus 7 (2012) 32 GB
Posted 06 June 2013 - 02:53 AM
FDR - no joy.
Thanks,
RMD
Uninstall the Google Music update and then voice commands will begin working immediately.  I had this issue when I updated Google Music after Google I/O released the update. Trust me - I thought it would've been the Google Search update but after removing all updates one by one, that was the one that fixed it.
#4 rduckwor
rduckwor
  • 29 posts
Posted 06 June 2013 - 04:10 AM
Thanks.
I will give it a try.
RMD
#5 DerekWeber
DerekWeber
    Non contributing ass
  • 345 posts
  • Twitter:@DerekWeber
  • Google+:www.google.com/+DerekWeber
  • LocationJeffery Dahmer's fridge
  • Current Device(s):Bionic, Semaphore Flags
Posted 08 June 2013 - 03:31 AM
There's an update in the play store for voice search that will correct the problem. Just dropped yesterday.
  • vdubdan87 likes this
Brrrrrrr... Where's my head?
#6 rduckwor
rduckwor
  • 29 posts
Posted 09 June 2013 - 03:47 PM
Yes, got it today.  Thanks.  In the interim period I follwed the above suggestion and dumped the Google Music updates and it came back fine.
Thanks all for the help.
RMD
