Ok so I am rooted and have an unlocked bootloader. I have attempted to flash cwm but not sure if it worked.... is there a way that I can tell? If I have not loaded it how do I do it.
Help with CWM or TWRP
Posted 07 June 2013 - 06:46 PM
Posted 07 June 2013 - 07:11 PM
ok so disregard the above post I used matts utility for 4.1.2 and flashed cwm.... now I know this seems like a stupid question but anyone wanna run through a quick instruction on how to flash a rom without an sd card???
#3 Guest_BDH_*
Posted 07 June 2013 - 07:40 PM
Download ROM
Plug phone into computer
Put ROM (gapps if needed) on internal memory
Flash same way
Flash gapps (if needed)
Reboot
Profit
- shane1 likes this
Posted 07 June 2013 - 07:56 PM
BigDaddyHicks... this may be an elementary question but by internal memory you mean what??? could I just put the rom into the download file on my phone and flash from there?
#5 Guest_BDH_*
Posted 07 June 2013 - 08:07 PM
Yes sir When you plug your phone into your PC it will read it as a disk drive (as long as you have the drivers installed). Put the ROM into a folder on your phone and follow the rest of the steps to install
Posted 07 June 2013 - 08:19 PM
BDH I just flashed dead rage 1.4 and after all loaded I have no network connection, I am also trying to add my google account and it pulls up the "new" or "existing" menu i click existing, it then takes me to the settings menu which is toggled off and doesnt allow me to do anything. ??? any ideas as to what is going on here
#7 Guest_BDH_*
Posted 07 June 2013 - 09:06 PM
You should post in the DeadRage thread. You might have to flash a different kernel or something.
