[Port] Xylon ROM (Placeholder)
#1 Guest_BDH_*
Posted 08 June 2013 - 03:07 AM
- shane1 and sfg like this
Posted 08 June 2013 - 03:34 AM
EDIT.... just looked it up with my magical Google powers and it is AOSP.
Posted 08 June 2013 - 08:11 AM
Good luck, Xylon is the hardest port I've attempted.
#4 Guest_BDH_*
Posted 08 June 2013 - 11:52 AM
#5 Guest_BDH_*
Posted 08 June 2013 - 02:37 PM
Posted 08 June 2013 - 03:58 PM
Question:
Did you use the master branch of
#7 Guest_BDH_*
Posted 08 June 2013 - 04:17 PM
Question:
Did you use the master branch of android_device_motorola_msm8960-common or did you use cm-10.1?
msm8960_common
Ran into a little bit of trouble. Kept erroring out because of some HTC stuff. Its building now though.
In your .repo/manifests/.git folder, I had a little issue with "HEAD" file as well but I just had to edit it to say "refs/heads/default"
Posted 08 June 2013 - 04:33 PM
msm8960_common
Yes, but what "revision" as it is called in the manifest. cm-10.1 or master?
master is for AOSP based stuff, which Xylon is. cm-10.1 for CM based stuff. Save yourself some build errors... :
#9 Guest_BDH_*
Posted 08 June 2013 - 05:08 PM
I'm using the master aosp revision. Ran into some kernel issues so far but got that fixed up and now it's building without errors so far.
- shane1 likes this
Posted 08 June 2013 - 05:17 PM
Hey BDH hears one for you where does E=mc2 come in at?? LOL
Puff the Magic Dragon
#11 Guest_BDH_*
Posted 08 June 2013 - 05:18 PM
I'll keep this thread updated with my progress, been getting quite a bit of errors and doing a lot of reading lol. I'll update as I go though!
- triskropf97 likes this
Posted 08 June 2013 - 05:36 PM
Cool I will be watching it. I cant tell by the pig latin that's up there LOL. But keep up the good work. Just don't get burned out.......
Posted 08 June 2013 - 06:34 PM
#14 Guest_BDH_*
Posted 08 June 2013 - 06:42 PM
Are we cracking yet
Nope, this is a long process, especially when you keep getting errors. Like I said, I'll keep this thread updated with progress.
Posted 13 June 2013 - 04:11 PM
any progress? The masses await a new flash
sig made by
Rinkle McBally
Posted 13 June 2013 - 07:50 PM
- shane1 and jeremym like this
#17 Guest_BDH_*
Posted 13 June 2013 - 11:53 PM
sent from my Raged out S3 using Tapatalk 4 beta
- drewrivera likes this
Posted 14 June 2013 - 09:38 AM
I guess question is to papi then. Are we cracking soon?
- Gytole and shane1 like this
Posted 17 July 2013 - 08:59 AM
so much for this rom ....guess some things weren't ment to be ...
- zooyork0721 likes this
Posted 17 July 2013 - 09:34 AM
Maybe this is why we have a 'development' subforum...
- DroidAddict101 likes this
