hello i tried flashing my first rom, the energy rom, i made a backup twrp 2.3.2.3 wiped cache, dalvik, factory reset, and then did system, now i cant figure out how to put energy on my phone, i am so confused, and now i found where my backup was, but the .zip file isnt showing up??? so now i have a phone that doesnt work, uh oh, i tried setting up adb like they explained in the forum, but when ever i open up cmd and type adb it says adb is not reconized
i lost my os
eroupe117
, Jun 09 2013 07:15 AM
4 replies to this topic
Posted 09 June 2013 - 07:15 AM
Posted 09 June 2013 - 09:05 AM
i put my sd card in my computer and put energy rom on it, then put it back in my phone and it keeps failing when i try to instal?? i am so confused it could probably be fixed i just have no idea what im doing i am very new at this
Posted 09 June 2013 - 09:17 AM
Are you mounting system right before flashing??
- eroupe117 likes this
Posted 09 June 2013 - 09:33 AM
Yes I clicked the mount system button, I have everything clicked, but now I only can boot into fast boot, I can't seem to get back into recovery, so Im downloading matt's utility and hopefully that can fix me?? But I havent done the ota 4.1.2 update yet, and I could only fine a matt's utility for 4.1.2 so I guess I'll just try that one, its almost done downloading
Posted 09 June 2013 - 04:07 PM
OK ha I found out what went wrong... My card reader was no good, went to best buy got a new card reader and put the ROM on it and flashed it I'm good to go, thanks for responding
- neckchop likes this
