New member here. hoping someone can give me some easy step by step on how to downgrade my razr from jb 4.1.2 to ics or anything older. I'm trying to activate it on a smaller carrier but revol wireless cant flash the newer 4.1.2. Any assistance would be greatly appreciated. thanks in advance.
help: downgrade from jb to ics
Posted 09 June 2013 - 05:40 PM
#2 Guest_BDH_*
Posted 09 June 2013 - 05:47 PM
If you have an XT912 you cannot downgrade.
- shane1 likes this
Posted 09 June 2013 - 05:56 PM
thanks for the quick response. would there happen to be any other way to get around the revol wireless issue of not being able to flash an android 4.1.2 phone?
#4 Guest_BDH_*
Posted 09 June 2013 - 06:10 PM
Sorry i'm not going to be of much help, I don't know anything about Revol Wireless. If your RAZR is CDMA and is on 4.1.2 then you can root it and put a recovery on it.
