CPU frequency with No-Frills CPU going past min/max?
Posted 10 June 2013 - 06:54 AM
And also on a side note, what are good min/max to set if you're trying to under clock for best battery experience? Thanks!
Posted 10 June 2013 - 10:14 AM
Posted 10 June 2013 - 06:43 PM
Posted 10 June 2013 - 07:11 PM
Posted 10 June 2013 - 07:20 PM
Yeah but it went past the second highest frequency (the one that I set as max) and up to the highest frequency possible (I set the max to 1 ghz and it went up to 1.3 ghz) it keeps fluctuating back, like it will go down to 1 ghz for a little bit and then back up to 1.3 ghz for a couple of seconds, then back down, etc. All this while on Performance. And yes I believe it does show realtime frequency
Posted 11 June 2013 - 01:11 AM
Posted 11 June 2013 - 01:29 AM
Just ignore the widget.
Posted 11 June 2013 - 04:00 AM
Posted 11 June 2013 - 05:34 AM
You should be good with SetCPU
- jl90 likes this
Posted 11 June 2013 - 02:49 PM
Actually, now I'm having a problem because for some reason it seems as if SetCPU as well is just ignoring the profiles and doing it's own thing...when I open SetCPU it shows the max and min as 1325 and 300 when my profile for Screen On (max priority as well) is 800/250You should be good with SetCPU
Posted 11 June 2013 - 02:55 PM
Posted 11 June 2013 - 03:09 PM
Posted 11 June 2013 - 03:21 PM
Posted 11 June 2013 - 03:27 PM
Posted 11 June 2013 - 03:30 PM
Posted 11 June 2013 - 03:36 PM
Version 3.0.9
Posted 11 June 2013 - 03:50 PM
Posted 11 June 2013 - 03:53 PM
Posted 11 June 2013 - 03:59 PM
Posted 11 June 2013 - 04:01 PM
My problem is whatever's on the main tab always overrides the profiles that are supposed to be playing. I want the overclock priority higher than the underclock (I always leave one or the other unchecked anyways)
