CPU frequency with No-Frills CPU going past min/max?
#21
Posted 11 June 2013 - 04:17 PM
#22
Posted 11 June 2013 - 04:25 PM
No I don't have overclock/underclock options, those are just what I named my profiles lol
- jl90 likes this
#23
Posted 11 June 2013 - 04:32 PM
#24
Posted 11 June 2013 - 04:38 PM
Maybe it's just user error...I've had this problem with the ROM Breakneck Blur as well as the Stock ROM. Do I usually need to reboot after I enable profiles for them to work correctly?
#25
Posted 11 June 2013 - 04:42 PM
#26
Posted 11 June 2013 - 04:47 PM
#27
Posted 11 June 2013 - 05:05 PM
I went to the ROM, wiped cache and dalvik, and then came back and cleared the data for SetCPU, and now it seems to be working fine...I wonder why it was like this in the first place though? I really hope it doesn't start acting up again, but either way thanks a lot for all of the help!!
#28
Posted 11 June 2013 - 05:15 PM
Actually scratch that, it just started doing the same thing. It's whenever I turn the screen off and then back on, it just always seems to go back to 1325 max/300 min (I don't even have 300 mhz programmed with my kernel)
#29
Posted 11 June 2013 - 05:24 PM
#30
Posted 11 June 2013 - 05:27 PM
I know the profile is on however because I set a notification to appear and it does without fail every time whenever the screen turns on...it's just simply not working for some reason. Maybe I should try emailing the person who made it?
#31
Posted 11 June 2013 - 05:36 PM
#32
Posted 11 June 2013 - 06:20 PM
Maybe there's just a bug in SetCPU that causes the frequency on the main tab to be off? Because the profiles are being recognized as in they show up on the notifications when they activate, but when I actually open SetCPU the frequency is completely off, so I'm just going to email them or something and see if its a bug. That's honestly all I can think of at this point, I've searched everywhere and I can't find an answer anywhere else.
#33
Posted 11 June 2013 - 06:23 PM
